Introduction
If you are experiencing problems like improper functionality, glitches with the sound or even problems with the touch controls, replacing a damaged motherboard can resolve this issue. This guide provides step by step instructions to completing this replacement.
Ce dont vous avez besoin
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Pry off the mesh frame from the back side of the speaker with a plastic spudger until you hear a click noise when the clip is removed.
Remove the two 11 mm Philips #1 screws holding down the motherboard.
Lift the motherboard from the plastic frame.
