Introduction
If you are experiencing problems connecting to the Wi-Fi or if it is not connecting at all, then replacing the Wi-Fi adapter can resolve this issue.
Ce dont vous avez besoin
Remove the rubber from the bottom of the speaker, use a medium blue plastic spudger to gently work its way under the rubber and slowly peel off for each of the three feet. The order does not matter.
Pry off the mesh frame from the back side of the speaker with a plastic spudger until you hear a click noise when the clip is removed.
Un commentaire
Hi There, Would you please show us how to open the iHome iPL8 to fix the brocken antenna cable. Thank you!
Kimberley2102@hotmail.com
