Aller au contenu principal
iLive IKBC384S Disk Drive Replacement
Ce dont vous avez besoin
  1. iLive IKBC384S Disk Drive Replacement, Top Cover: étape 1, image 1 de 2 iLive IKBC384S Disk Drive Replacement, Top Cover: étape 1, image 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Disk Drive Replacement: étape 2, image 1 de 2 iLive IKBC384S Disk Drive Replacement: étape 2, image 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Disk Drive Replacement: étape 3, image 1 de 2 iLive IKBC384S Disk Drive Replacement: étape 3, image 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Disk Drive Replacement, Disk Drive: étape 4, image 1 de 2 iLive IKBC384S Disk Drive Replacement, Disk Drive: étape 4, image 2 de 2
    • Remove all four screws(13.5 mm in length) that are securing the device
  5. iLive IKBC384S Disk Drive Replacement: étape 5, image 1 de 2 iLive IKBC384S Disk Drive Replacement: étape 5, image 2 de 2
    • Remove both of the connected cords on the motherboard.
    • Also remove the flat ribbon cable that is connected to the motherboard.
    • Once you have removed all screws and cables connected to motherboard the disk drive can be easily removed
Allen Dover
Membre depuis le 03/21/17
401 Réputation
4 tutoriels rédigés
Équipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 431
