Aller au contenu principal
iLive IKBC384S Motherboard Replacement
Ce dont vous avez besoin
  1. iLive IKBC384S Motherboard Replacement, Top Cover: étape 1, image 1 de 2 iLive IKBC384S Motherboard Replacement, Top Cover: étape 1, image 2 de 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S Motherboard Replacement: étape 2, image 1 de 2 iLive IKBC384S Motherboard Replacement: étape 2, image 2 de 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S Motherboard Replacement: étape 3, image 1 de 2 iLive IKBC384S Motherboard Replacement: étape 3, image 2 de 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  5. iLive IKBC384S Motherboard Replacement: étape 5, image 1 de 2 iLive IKBC384S Motherboard Replacement: étape 5, image 2 de 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Disconnect the two power connectors from the motherboard.
  6. iLive IKBC384S Motherboard Replacement: étape 6, image 1 de 1
    • You will need to desolder the antenna.
    • Be sure to desolder the piece connected to the motherboard not the wire.
  7. iLive IKBC384S Motherboard Replacement: étape 7, image 1 de 1
    • You will need to remove the speakers and power connector.
    • Once you have removed all of these from the motherboard, the motherboard can be removed
Tracy Walts
Membre depuis le 03/21/17
201 Réputation
2 tutoriels rédigés
Équipe
Texas Tech, Team S46-G6, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 290
