Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iMac 27" 2017 Thermal Paste Replacement
Ce dont vous avez besoin
Instructions vidéo
To reassemble your device, follow these instructions.
3 autres ont terminé cette réparation.
Arty
Membre depuis le 10/27/19
33 741 Réputation
110 tutoriels rédigés
4 commentaires de tutoriel
what is the thickness of the gaskets?
Andrey Kushnir - Réponse Partager
The GPU RAM Thermal Pads are 1.5 thick.
While Apple used a thicker gaping paste (white in color) as it was easier to used on a factory floor. It was not very effective in transferring the heat away. The quality of the thermal pad also plays a role here as well as the GPU's thermal paste. We need to move the heat from the GPU effectively as its heat ramp up can be quite fast, but we don't want to dump the heat sink heat to the RAM so we don't want to effective movement of heat transferring in the wrong direction. This is more so when heavy graphics are being run. It is advised to install a good thermal monitoring App watching once's thermals and ramping up the fans RPM to more aggressively cool the system during heavy work loads.
DanJ - Réponse Partager
I used the 1.5 mm Thermal pads and found them to be too thick, which caused alignment of the heat sink to be slightly different which caused the alignment of the hidden screw hole to not be in the correct position, which didn't allow me to insert and tighten the screw....I ended up using the old paste, but will need to open it up again to finish the job...
S. Baxter - Réponse Partager
I always measure the gap as Apple uses a few different venders. I’ve often need to use 1.0 mm. Don’t reuse the old paste stick with the pads.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 42
30 derniers jours : 176
Total : 8,770
