Aller au contenu principal
iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement
Ce dont vous avez besoin
  1. iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: étape 1, image 1 de 2 iMac 27" Mid-2011 Broken Display Power Connector Pins Replacement, Locate broken pin: étape 1, image 2 de 2
    • This can be a connector within the iMac or another board for parts. I found an unused connector in my computer.
    • Apply the soldering iron to the base of the broken pin connected to the circuit board while levering the tweezers behind it pulling it out slowly.
    • Same as previous step.
    • Slide the pin in the desired connector until it is firmly seated inside.
    • Apply pressure to the base of the pin with the tweezers and solder the pin back in place.
Ligne d'arrivée
Mathew Mulligan
Membre depuis le 07/17/17
143 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 68
Total : 4,696
