Aller au contenu principal
iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement
Ce dont vous avez besoin
  1. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: étape 1, image 1 de 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: étape 1, image 2 de 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement: étape 2, image 1 de 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: étape 3, image 1 de 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: étape 3, image 2 de 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
    You to not need to remove the RAM to complete this task.
    douglux - Réponse
10 autres ont terminé cette réparation.
Ryan Kozak
Membre depuis le 10/10/11
1 675 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-32, Amido Fall 2011 Membre de l'équipe Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 membres
8 tutoriels rédigés
2 commentaires
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Réponse
Thanks For catching this Typo! :-)
Ben Capehart -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 19
Total : 5,723
