Ce dont vous avez besoin
Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
Remove the 2 torx 10mm screws on the EMI shield
Carefully remove shield and copper tape
Peel back the white paper, revealing the screws that connect the hard drive to the carrier.
Remove the 4 T-10 5mm screws connecting the hard drive and frame. (There are 2 screws on each side)
Before you reassemble the computer, double check that your new hard drive has the same jumper configuration as the old one. This ensures the IDE "Master-Slave" protocol isn't interrupted. Some systems do not require this, but if you are having issues booting up afterwards with the storage or the disc drive, this could be the source of the problem.
27 autres ont terminé cette réparation.
