Introduction
Replace your modem and re-introduce yourself to the joys of 56k.
Ce dont vous avez besoin
Lay the iMac display-side down on a flat surface.
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
Slightly lift the AirPort bracket off the logic board.
3 autres ont terminé cette réparation.
