Aller au contenu principal
iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement
Ce dont vous avez besoin
  1. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement, Access Door: étape 1, image 1 de 1
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 2, image 1 de 1
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement, Front Bezel: étape 3, image 1 de 1
    • Remove the three T8 Torx screws securing the front bezel to the rear panel.
  4. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 4, image 1 de 2 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 4, image 2 de 2
    • Orient the iMac face-up, on its backside.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 5, image 1 de 1
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 6, image 1 de 3 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 6, image 2 de 3 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  7. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 7, image 1 de 1
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 8, image 1 de 1
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  9. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 9, image 1 de 2 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 9, image 2 de 2
    • Disconnect both the camera and microphone cables.
  10. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement, AirPort/Bluetooth Board: étape 10, image 1 de 1
    • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
    • It is not necessary to peel the EMI shield off the display.
    • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
  11. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 11, image 1 de 2 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 11, image 2 de 2
    • Remove the single T10 Torx screw securing the right speaker to the rear case.
    • Pull the rear speaker out of the rear case, and move it out of the way.
    • It is not necessary to disconnect the right speaker.
  12. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 12, image 1 de 2 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 12, image 2 de 2
    • Remove the two T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
    • Lift the AirPort/Bluetooth board up from its left edge to separate it from its socket on the logic board.
    • Lift the AirPort/Bluetooth board from its left edge only. Trying to lift from its right edge may break the socket off the logic board.
  13. iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 13, image 1 de 2 iMac G5 17" Model A1144 AirPort/Bluetooth Board Replacement: étape 13, image 2 de 2
    • Use the flat end of a spudger to pry the AirPort and Bluetooth antenna connectors up off the AirPort/Bluetooth board.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 7,923
