Introduction
iSight not working? Replace your camera board.
Ce dont vous avez besoin
Remove the three T8 Torx screws securing the front bezel to the rear panel.
Outil utilisé dans cette étape :Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Lay the bezel front side down on a table.
If necessary, peel back the tape covering the camera board.
