Aller au contenu principal
iMac G5 20" Model A1076 Hard Drive Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iMac G5 20" Model A1076 Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Remove the following three screws:
    • One shouldered 12.4 mm Phillips.
    • Two 7 mm T10 Torx.
  2. iMac G5 20" Model A1076 Hard Drive Replacement: étape 2, image 1 de 1
    • The following action is optional. If you skip this step, be very careful not to strain the thermal sensor cable as you disconnect the hard drive cables and transfer this bracket to your new hard drive.
    • Lift the hard drive slightly and disconnect the hard drive thermal sensor connector.
  3. iMac G5 20" Model A1076 Hard Drive Replacement: étape 3, image 1 de 2 iMac G5 20" Model A1076 Hard Drive Replacement: étape 3, image 2 de 2
    • Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
    • Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
    • Repeat this process for the SATA power connector.
  4. iMac G5 20" Model A1076 Hard Drive Replacement: étape 4, image 1 de 1
    • Lift the hard drive out of the iMac.
    • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 1
Total : 1,144
