Introduction
Reclaim your chat capabilities, use this guide to replace your combination iSight camera and microphone cable.
Ce dont vous avez besoin
Outil utilisé dans cette étape :iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Outil utilisé dans cette étape :Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the iSight camera cable.
3 autres ont terminé cette réparation.
Un commentaire
Excellently described procedure - it worked ok not disconnecting the AC power cable. Only item missed was to disconnect the right speaker - and then not to forget about keeping it out ready to connect when reinstating the mother board!
Thank you very much
