Introduction
Follow the steps in this guide to replace the front panel in a 21.5" Retina 4K 2017 iMac.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
This procedure involves removing the faulty/broken display, as well as transferring the display data cable and thermal sensor to a new display.
Ce dont vous avez besoin
Outil utilisé dans cette étape :iMac Intel 21.5" Cardboard Service Wedge$4.99
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Outil utilisé dans cette étape :Plastic Cards$2.99
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use your fingernail or the pointed tip of a spudger to flip up the retaining flap on the display data connector.
12 autres ont terminé cette réparation.
7 commentaires
Great work, done in 35 min. Thanks :)
What is the part number for a replacement screen for an iMac Intel 21.5” Retina 4K Display (Apple Model No. A1418, EMC 3069)? Does ifixit carry them?
Hey there, I am in the same situation.
My screen has a crack in it, so I am ordering a replacement from Alibaba soon, but it seems like there are 2 part numbers associate with this iMac model:
LM215UH1-SDA1
LM215UH1-SDB1
Please let me know if you have found a solution.
Mr.Maker -
Mr. Maker, I ordered this one from ebay back in March: https://www.ebay.com/itm/323724320252
The part number was LM215UH1 (SD)(B1) and worked perfectly. Really easy repair. Good luck!
Hi, unfortunately I cracked the front glass of the 4k lcd, so I wonder if there is the possibility to replace only the glass instead of the whole lcd assembly.
Please le me know. thanks for support
Alessio
