Aller au contenu principal
Introduction
Use this guide to replace the left speaker in your 21.5" Retina 4K Display 2019 iMac.
Some images in this guide use an older iMac, which has minor visual differences. These differences do not affect the repair procedure.
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Place an iMac service wedge, in the stand to stabilize the iMac.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  1. Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Starting on the left side of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
  2. Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display. Be sure to always push with the cutting wheel forward. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
    • Use the tool like a pizza cutter—roll it along the gap, cutting the foam adhesive in between the frame and display.
    • Be sure to always push with the cutting wheel forward. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  3. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
    • Continue running the tool up around the top left corner.
  4. Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
    • Cut the adhesive along the top left of the display.
  5. Continue along the top of the display. You may want to run the tool back and forth a few times to ensure you completely cut through the adhesive.
    • Continue along the top of the display.
    • You may want to run the tool back and forth a few times to ensure you completely cut through the adhesive.
  6. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
    • Push the tool around the top right corner of the display.
  7. Push the tool down along the right side of the display. Push the tool down along the right side of the display.
    • Push the tool down along the right side of the display.
  8. Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  9. While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  10. Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  11. Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  12. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  13. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  14. Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  15. Slide the plastic card toward the center. Stop sliding just before the iSight camera to avoid damaging the camera. Stop sliding just before the iSight camera to avoid damaging the camera.
    • Slide the plastic card toward the center.
    • Stop sliding just before the iSight camera to avoid damaging the camera.
  16. Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
    • Wedge the plastic card back into the top left corner.
  17. With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  18. Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8"). Hold the display with one hand while using your other hand to unplug the display power cable.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
  19. Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
  20. Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  21. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
  22. Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
  23. Remove the following five Phillips  screws holding the lower support bracket in place: Four 3.2 mm screws
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  24. Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
  25. Gently pull the fan cable connector straight away from its socket on the logic board. Gently pull the fan cable connector straight away from its socket on the logic board.
    • Gently pull the fan cable connector straight away from its socket on the logic board.
  26. Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • Remove the three 10 mm T10 Torx screws securing the fan to the rear enclosure.
    • The uppermost screw has a rubber standoff adhered to its head to support the display—leave this in place.
  27. Remove the fan from the iMac. Remove the fan from the iMac.
    • Remove the fan from the iMac.
  28. Gently pull the left speaker cable straight out of its socket on the logic board. Gently pull the left speaker cable straight out of its socket on the logic board.
    • Gently pull the left speaker cable straight out of its socket on the logic board.
  29. De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
    • De-route the left speaker cable by pulling it straight up out of the retaining clip in the back of the rear enclosure.
  30. Use a spudger to disconnect the power button connector from its socket on the logic board. Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock. Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
  31. Remove the two 10.0 mm T10 screws securing the left speaker to the rear case.
    • Remove the two 10.0 mm T10 screws securing the left speaker to the rear case.
    • Rubber washers keep the screws snug in the speaker even when loosened. You can use tweezers or a fingernail to remove the screws, or simply leave them with the speaker assembly.
  32. Lift the left speaker straight up, until the power button cable is exposed (about 0.5"). Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5").
  33. Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker. Gently de-route the power button cable from its groove in the left speaker.
    • Gently de-route the power button cable from its groove in the left speaker.
  34. Lift the left speaker straight up and remove it from the iMac. Lift the left speaker straight up and remove it from the iMac. Lift the left speaker straight up and remove it from the iMac.
    • Lift the left speaker straight up and remove it from the iMac.
Adam O'Camb
Membre depuis le 11/04/2015
140 296 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
138 membres
16 439 tutoriels rédigés
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 219
