Aller au contenu principal
iMac Intel 24" EMC 2111 IR Board Replacement
Ce dont vous avez besoin
  1. iMac Intel 24" EMC 2111 IR Board Replacement, Access Door: étape 1, image 1 de 2 iMac Intel 24" EMC 2111 IR Board Replacement, Access Door: étape 1, image 2 de 2
    • Loosen the two Phillips screws securing the access door to your iMac.
    • Both screws remain captive within the access door.
    • Remove the access door.
  2. iMac Intel 24" EMC 2111 IR Board Replacement, Front Bezel: étape 2, image 1 de 1
    • Remove the following screws along the lower edge of your iMac:
    • Three 6 mm T8 Torx screws
    • One 8 mm T8 Torx screw
  3. iMac Intel 24" EMC 2111 IR Board Replacement: étape 3, image 1 de 2 iMac Intel 24" EMC 2111 IR Board Replacement: étape 3, image 2 de 2
    • Lay your iMac stand-side down on a flat surface.
    • To lift the front bezel off the iMac, simultaneously:
    • Use your thumbs to press in the RAM arms and hold the iMac down.
    • Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
    • Pull the front bezel up with your index fingers.
    • Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
  4. iMac Intel 24" EMC 2111 IR Board Replacement: étape 4, image 1 de 3 iMac Intel 24" EMC 2111 IR Board Replacement: étape 4, image 2 de 3 iMac Intel 24" EMC 2111 IR Board Replacement: étape 4, image 3 de 3
    • Lift the front bezel off the rear case and rotate it away from the bottom edge of the iMac, minding the camera and microphone cables still attached to its upper edge.
    • The third picture shows the top front bezel brackets and their slots cut into the top edge of the iMac's rear case.
    • Do not completely remove the front bezel, as it is still attached by the camera/microphone cables.
  5. iMac Intel 24" EMC 2111 IR Board Replacement: étape 5, image 1 de 1
    • If necessary, remove the strip of tape covering the microphone cable connector.
    • The microphone connector is located near the inside of top edge of your iMac.
  6. iMac Intel 24" EMC 2111 IR Board Replacement: étape 6, image 1 de 3 iMac Intel 24" EMC 2111 IR Board Replacement: étape 6, image 2 de 3 iMac Intel 24" EMC 2111 IR Board Replacement: étape 6, image 3 de 3
    • Disconnect the microphone cable.
    • Disconnect the camera cable by pulling its connector away from the socket on the camera board.
    • The camera cable connector and socket are delicate and easily bent. Remove with caution.
  7. iMac Intel 24" EMC 2111 IR Board Replacement, IR Board: étape 7, image 1 de 1
    • The IR board is located above the RAM modules socket, near the lower, center portion of the iMac.
    • Remove the single T6 Torx screw securing the small IR board.
  8. iMac Intel 24" EMC 2111 IR Board Replacement: étape 8, image 1 de 1
    • Pull the small IR board slightly away from the iMac and disconnect its cable.
    • Set it aside.
  9. iMac Intel 24" EMC 2111 IR Board Replacement: étape 9, image 1 de 2 iMac Intel 24" EMC 2111 IR Board Replacement: étape 9, image 2 de 2
    • Remove the remaining T6 Torx screw securing the other IR board to the logic board.
    • De-route the IR cables from the metal shield behind the IR board and remove the shield from the iMac.
  10. iMac Intel 24" EMC 2111 IR Board Replacement: étape 10, image 1 de 1
    • Disconnect the second IR board and remove it from the iMac.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 22
Total : 1,776
