Introduction
Use this guide to replace a broken LCD.
Pièces
Aucune pièce spécifiée.
Loosen the two Phillips screws securing the access door to your iMac.
Remove the access door.
Remove the following screws along the lower edge of your iMac:
Three 6 mm T8 Torx screws
One 8 mm T8 Torx screw
To lift the front bezel off the iMac, simultaneously:
Use your thumbs to press in the RAM arms and hold the iMac down.
Use your index fingers to pull the small bridge of material on the front bezel toward yourself.
Pull the front bezel up with your index fingers.
Once the small bridge of material has cleared the RAM arms, lift the front bezel by its lower edge just enough to clear the bottom edge of the rear case.
Peel the two highlighted EMI shield tabs off the frame of the LCD.
Remove the two pieces of tape securing the display data cable to the back of the display.
Remove the large piece of tape covering the inverter cable connector and any tape securing the cable to the inverter board.
2 autre(s) ont terminé cette réparation.
