Introduction
Use this guide to replace the AirPort card.
Outils
Pièces
Aucune pièce spécifiée.
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
Lay the display face down on a flat, soft surface.
If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Locate the AirPort card at the top center of the logic board and just below the hard drive.
Use the flat end of a spudger to gently pry each of the antenna cables off their sockets.
11 autre(s) ont terminé cette réparation.
5 commentaires
I have a question, and I hope that this is the right place to ask. Can I replace the original Airport card with a BROADCOM BCM94360CD and a minicpi adaptor and get 802.11AC and Bluetooth 4.0? I know the BCM94360CD has four antenna connectors and the original Airport card only has three. Any guidance there? The connectors on the BCM94360CD are labeled "J0", "J1", "J2" and "J3". Thanks in advance!
Google osxwifi. The extra connector is Bluetooth. 2011 it was 2 separate cards, the newer models are combo Bluetooth + wifi AC cards. Because of this, The pci adapter needs the USB pins, and an extension cable for the BT antenna to work with 2011 models. I've done that mod to my mid 2011 27" iMac.
joer293 -
This may sound silly but I am installing the Broadcom Bcm94360cd so I can have hand off in my mid 2011 27" iMac. I was wondering where does the USB cable get plugged in? Also do I have to remove the actual Bluetooth card since it's a separate piece in order for this to work? Please help. Thank You.
I am also installing the upgrade kit. Do you already know where does the usb cable get plugged in and if it is necessary to remove Bluetooth card? Thank you!
