Introduction
Use this guide to replace the camera board.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Suction Cups (Pair)$14.95
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Carefully lay the iMac stand-side down on a flat surface.
Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
Raise and hold the display high enough to access the cables.
Lay the display face down on a flat, soft surface.
If there is a wire or cable underneath adhesive tape, always pull the tape off first. Do not pull on the cable directly.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Remove the two T10 Torx screws securing the camera board to the outer case.
5 autres ont terminé cette réparation.
