Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement
Ce dont vous avez besoin
  1. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Install the service wedge: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    iMac Intel 27" Cardboard Service Wedge
    Demander à FixBot
    Ajouter un commentaire
  2. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Insert an opening tool: étape 2, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Insert an opening tool: étape 2, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Insert an opening tool: étape 2, image 3 de 3
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert it no more than 3/8" (9.5 mm) into the display. You risk severing antenna cables and causing serious damage if you insert the tool too far.
    Demander à FixBot
  3. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Slice through the display adhesive: étape 3, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Slice through the display adhesive: étape 3, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Slice through the display adhesive: étape 3, image 3 de 3
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    Demander à FixBot
  4. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Cut through the remaining adhesive: étape 4, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Cut through the remaining adhesive: étape 4, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Cut through the remaining adhesive: étape 4, image 3 de 3
    • Continue wheeling the tool up around the top left corner.
    Demander à FixBot
  5. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 5, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 5, image 2 de 2
    • Cut the adhesive along the top left of the display.
    Demander à FixBot
  6. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 6, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 6, image 2 de 2
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    Demander à FixBot
  7. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 7, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 7, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 7, image 3 de 3
    • Push the tool around the top right corner of the display.
    Demander à FixBot
  8. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 8, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 8, image 2 de 2
    • Wheel the tool down along the right side of the display.
    Demander à FixBot
  9. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 9, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 9, image 2 de 2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    Demander à FixBot
  10. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 10, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 10, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 10, image 3 de 3
    Plastic Cards
    $2.99
    • While the opening tool did the lion's share of the work, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
    • Be careful not to insert it more than 3/8" (9.5 mm), or you may damage internal components.
    Demander à FixBot
  11. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 11, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 11, image 2 de 2
    • Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
    • Using too much force will crack the glass. Work carefully, and don't try to create a gap any larger than about 1/4" (6 mm).
    Demander à FixBot
  12. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 12, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 12, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 12, image 3 de 3
    • Be sure to stop cutting before the iSight camera in this step, or you may damage it.
    • Slide the card toward the center of the display, to cut any remaining adhesive.
    Demander à FixBot
  13. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 13, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 13, image 2 de 2
    • Put the card into the corner again and let it stay there to keep the adhesive from resettling.
    Demander à FixBot
  14. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 14, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 14, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 14, image 3 de 3
    • Insert a second card into the gap between the display and frame in the top left corner.
    Demander à FixBot
  15. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 15, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 15, image 2 de 2
    • Gently twist the card, slightly increasing the space between the display and frame.
    • As with the other side, move slowly to allow the adhesive to break, and be careful not to over-stress the display glass.
    Demander à FixBot
  16. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 16, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 16, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 16, image 3 de 3
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
    Demander à FixBot
  17. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 17, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 17, image 2 de 2
    • Insert the card back into the top left corner.
    Demander à FixBot
  18. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 18, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 18, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 18, image 3 de 3
    • With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—it is still attached to the iMac by data and power cables.
    Demander à FixBot
  19. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Disconnect the display cables: étape 19, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Disconnect the display cables: étape 19, image 2 de 2
    • While holding the display up with one hand, use the other to unplug the display power cable.
    • Lift the display up enough to have easy access to the connections, but not so much that you stretch the cables and stress their connections (about 8").
    Demander à FixBot
  20. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 20, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 20, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 20, image 3 de 3
    • Flip up the metal retaining bracket on the display data cable.
    • Disconnect the display data cable.
    • This is a delicate connection that can easily be broken. Be sure to pull the display data cable connector straight out of its socket, toward the top of the iMac.
    Demander à FixBot
  21. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Lift the display: étape 21, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Lift the display: étape 21, image 2 de 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    Demander à FixBot
  22. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the remaining adhesive: étape 22, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the remaining adhesive: étape 22, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the remaining adhesive: étape 22, image 3 de 3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
    Demander à FixBot
  23. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the display: étape 23, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the display: étape 23, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the display: étape 23, image 3 de 3
    • Be very careful handling the display—it's big, heavy, and made of glass. The display has fragile edges. Avoid lifting the display by the corners.
    • Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow the adhesive replacement guide for your model when your repair is complete to replace the adhesive strips that secure the display to the rear enclosure.
    Demander à FixBot
  24. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the support bracket: étape 24, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the support bracket: étape 24, image 2 de 2
    • Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
    Demander à FixBot
  25. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 25, image 1 de 1
    • Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
    • How to easily reinstall this support bracket:
    • Position the bracket diagonally.
    • Secure the rightmost screw enough to hold the bracket in place; keep it loose for now so the bracket can pivot.
    • Swing the left side of the bracket down until it sits horizontally in its original position.
    • Starting with the leftmost screw, install and tighten the remaining screws.
    Demander à FixBot
  26. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement, Remove the left speaker: étape 26, image 1 de 1
    • Remove two 10 mm T10 screws.
    Demander à FixBot
  27. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 27, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 27, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 27, image 3 de 3
    • Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
    • De-route the cable from the gap between the hard drive and logic board.
    • If the gap between the hard drive and logic board is too narrow for the speaker cable, disconnect it and leave the cable in place.
    Demander à FixBot
  28. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 28, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 28, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 28, image 3 de 3
    • Be careful not to touch any solder joints on the back of the power supply. Capacitors may be charged enough to give you a dangerous shock.
    • Use a spudger to disconnect the power button connector from its socket on the logic board.
    Demander à FixBot
  29. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 29, image 1 de 2 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 29, image 2 de 2
    • Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
    Demander à FixBot
  30. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 30, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 30, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 30, image 3 de 3
    • Gently de-route the power button cable from its groove in the left speaker.
    Demander à FixBot
  31. iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 31, image 1 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 31, image 2 de 3 iMac Intel 27" Retina 5K Display 2020 Left Speaker Replacement: étape 31, image 3 de 3
    • Lift the left speaker straight up and remove it from the iMac.
    • If the gap between the hard drive and logic board was too narrow to free the speaker cable earlier, gently pull it free as you remove the speaker.
    • Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
    Demander à FixBot
Sam Omiotek
Membre depuis le 02/25/19
98 734 Réputation
290 tutoriels rédigés
1 commentaire de tutoriel
Do those speakers significantly add to any heat management issues in this iMac? I never use them. I was thinking about just getting rid of them and replacing them with some more fans or connecting another PCIe card or two to add on an extra internal GPU and extra internal SSD.
Christoph Curtis - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 66
Total : 2,349
