Introduction
In this part of the guide I am going to tutor you on how to replace the camera motherboard.
Detach the magnetic  clip from the bottom  of the camera.
  • Detach the magnetic clip from the bottom of the camera.
  • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
Ajouter un commentaire
Use a spudger to  gently detach  the  memory card and USB slot cover.
  • Use a spudger to gently detach the memory card and USB slot cover.
  • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
  • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  • Once again use the spudger to gently open the encasement.
  • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
  • The Battery can be safely detached and replaced.
  • To get to the motherboard, safely lift the battery to expose an Aluminium plate that shields and holds the motherboard in place.
  • The plates are held down by four Phillips 0.008 mm screws on all four corners. Use a Phillips head #000 to safely loosen the screws.
  • To replace the motherboard gently insert a plastic opening tool into one end and lift up.
  • Be careful to avoid inserting material that is rough and too sturdy as it can damage components on the motherboard.
Jessica Matias
Membre depuis le 09/12/2017
201 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S3-G3, Wilson Fall 2017 Membre de l'équipe IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 membres
3 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 68
