Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Pre-req for antennas
Pièces
Aucune pièce spécifiée.
  1. Carefully lay the LCD next to the rear panel. Use a plastic opening tool to lift the display data cable lock upwards. Pull the display data cable out of its socket.
    • Carefully lay the LCD next to the rear panel.
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Do not pull the connector upward as you disconnect it from its socket.
  2. Remove the LCD assembly from the rear panel assembly.
    • Remove the LCD assembly from the rear panel assembly.
Jake Devincenzi
Membre depuis le 18/04/2011
113 967 Réputation
57 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 503
