Introduction
Don't try this if you haven't experience !!!
How to replace / change broken glass / touch screen - Apple iPad2.
See also Remplacement du panneau frontal de l'iPad 2 Wi-FI EMC 2415
Ce dont vous avez besoin
Vidéo d'introduction
Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
Set the LCD back into the body for safekeeping.
4 autres ont terminé cette réparation.
Un commentaire
We replaced the screen successfully and it turns on all looks beautiful except the touch screen isn’t working at all—any thoughts? We are beginners
