Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPad 3G Communications Board Replacement
Ce dont vous avez besoin
  1. iPad 3G Communications Board Replacement, Display Assembly: étape 1, image 1 de 3 iPad 3G Communications Board Replacement, Display Assembly: étape 1, image 2 de 3 iPad 3G Communications Board Replacement, Display Assembly: étape 1, image 3 de 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Demander à FixBot
    Ajouter un commentaire
  2. iPad 3G Communications Board Replacement: étape 2, image 1 de 2 iPad 3G Communications Board Replacement: étape 2, image 2 de 2
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
    Demander à FixBot
  3. iPad 3G Communications Board Replacement: étape 3, image 1 de 2 iPad 3G Communications Board Replacement: étape 3, image 2 de 2
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
    Demander à FixBot
  4. iPad 3G Communications Board Replacement: étape 4, image 1 de 2 iPad 3G Communications Board Replacement: étape 4, image 2 de 2
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
    Demander à FixBot
  5. iPad 3G Communications Board Replacement: étape 5, image 1 de 1
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
    Demander à FixBot
  6. iPad 3G Communications Board Replacement: étape 6, image 1 de 1
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
    Demander à FixBot
  7. iPad 3G Communications Board Replacement: étape 7, image 1 de 1
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
    Demander à FixBot
  8. iPad 3G Communications Board Replacement: étape 8, image 1 de 3 iPad 3G Communications Board Replacement: étape 8, image 2 de 3 iPad 3G Communications Board Replacement: étape 8, image 3 de 3
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
    Demander à FixBot
  9. iPad 3G Communications Board Replacement: étape 9, image 1 de 1
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
    Demander à FixBot
  10. iPad 3G Communications Board Replacement: étape 10, image 1 de 2 iPad 3G Communications Board Replacement: étape 10, image 2 de 2
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
    Demander à FixBot
  11. iPad 3G Communications Board Replacement: étape 11, image 1 de 1
    • Remove the display assembly from the rear panel assembly.
    Demander à FixBot
  12. iPad 3G Communications Board Replacement, Communications Board: étape 12, image 1 de 1
    • Use the edge of an iPod opening tool to carefully pry the remaining antenna connector up off the communications board.
    Demander à FixBot
  13. iPad 3G Communications Board Replacement: étape 13, image 1 de 2 iPad 3G Communications Board Replacement: étape 13, image 2 de 2
    • De-route the control button cable along the top edge of the communications board.
    • Pull the communications cable upward to lift its connector up and out of the socket on the logic board.
    Demander à FixBot
  14. iPad 3G Communications Board Replacement: étape 14, image 1 de 1
    • Remove the single T5 Torx screw securing the communications board to the rear case.
    Demander à FixBot
  15. iPad 3G Communications Board Replacement: étape 15, image 1 de 2 iPad 3G Communications Board Replacement: étape 15, image 2 de 2
    • If necessary, lift the right edge of the communications board upward to release it from the adhesive pad attached to the rear case.
    • Pull the communications board away from its socket on the logic board.
    Demander à FixBot
11 autres ont terminé cette réparation.
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 66
Total : 16,655
