Aller au contenu principal
iPad 4 Wi-Fi Headphone Jack Assembly Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iPad 4 Wi-Fi Headphone Jack Assembly Replacement, Headphone Jack Assembly: étape 1, image 1 de 1
    • Carefully move, but do not remove the front-facing camera ribbon cable aside with the flat edge of a spudger.
    OR, if you’re having a problem with the front camera OR the ambient light sensor (which is the small module above the camera lens), go ahead and remove the front camera and swap in a new one, complete with sensor module. It is theoretically possible to remove and swap just the ambient light sensor module, but this author found it too difficult to be worth it, if it’s possible at all.
    [The ambient light sensor makes automatic adjustment of screen brightness possible, if you switch it on with the toggle under “screen and brightness” in settings. When working, the screen gets dimmer in dim settings and brighter in bright settings. It might sound unimportant, but if you’ve tried to take pictures in bright sunlight with a dim screen…you’ll appreciate it’s usefulness.]
    Bonnie Baxter - Réponse
  2. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 2, image 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 2, image 2 de 2
    • Peel back and remove the adhesive tape covering the headphone jack assembly.
  3. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 3, image 1 de 1
    • Using the tip of the spudger, flip up the retaining flap on the microphone cable ZIF connector.
  4. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 4, image 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 4, image 2 de 2
    • Insert the tip of the spudger underneath the microphone ribbon cable and carefully push it out from its socket on the ZIF connector.
    • Use the flat edge of a spudger to move the microphone ribbon cable aside.
  5. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 5, image 1 de 1
    • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
  6. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 6, image 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 6, image 2 de 2
    • Push the volume button ribbon cable from its ZIF connector.
    • Gently bend the volume button ribbon cable upwards to move it aside.
  7. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 7, image 1 de 3 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 7, image 2 de 3 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 7, image 3 de 3
    • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.2 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
    • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  8. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 8, image 1 de 1
    • Holding onto the ribbon cable of the headphone jack assembly, carefully pull the assembly upwards towards the top of the device.
  9. iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 9, image 1 de 2 iPad 4 Wi-Fi Headphone Jack Assembly Replacement: étape 9, image 2 de 2
    • Grasping the headphone jack assembly with one hand, pull the assembly from the iPad, minding any cables that may get caught.
Walter Galan
694 492 Réputation
1 203 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 38
