Introduction
Use this guide to replace the power & volume buttons.
We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
  • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
which temperature must be used for heating? Thx
fbarletta - Réponse
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - Réponse
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - Réponse
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - Réponse
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - Réponse
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - Réponse
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - Réponse
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - Réponse
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - Réponse
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - Réponse
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - Réponse
Heat the iOpener for thirty seconds.
  • Heat the iOpener for thirty seconds.
  • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
  • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
  • Never touch the iOpener if it appears swollen.
  • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - Réponse
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - Réponse
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - Réponse
I don't own a microwave.
mdanihy - Réponse
Its again waterproof when you change iphone 7 battery?
Jon - Réponse
I don't have a microwave???
Joe Blow - Réponse
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - Réponse
can i use just ordinary microwave???
juneseok kwon - Réponse
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - Réponse
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - Réponse
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - Réponse
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - Réponse
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - Réponse
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - Réponse
30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
60 seconds in the microwave, the iOpener burst.
I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
K
Karl Marble - Réponse
  • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
  • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
Will a hair dryer work for heating the glass?
Me berg - Réponse
Yes, as does a heat gun.
anonymous 4602 - Réponse
I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
Cobus de Beer - Réponse
  • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
  • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
  • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
Yes...wear safety glasses for sure when doing this!
Josh West - Réponse
If you have ANY cracks FOR SURE do the tape. I would also make sure to wear safety glasses as it can fly all over even with the tape. And do it somewhere that you don't mind tiny glass shards going everywhere. I had one 3 inch crack in the glass in the lower right corner and it started spidering. The plastic pics don't work once well once they hit a broken point in the glass so you better have a lot of heat to loosen the adhesive, or you end up using an exacto knife to get around the cracked spots.
jesseokerlund - Réponse
On a few occasions I had an unexpected pop as the glass shattered and little shards struck me in the face. I had taped the surface but pieces at the edge still managed to break free. My advice: definitely wear the safety glasses, and definitely tape the entire glass surface.
robertmhussey - Réponse
Echo jesseokerlund's comments that you will have glass flying. I made the mistake of doing the repair at my kitchen table and had a lot of cleanup to do. The job would be much easier if there was no broken glass, and the hardest part is where the glass is broken right next to the bezel. I used the metal spudger to work those pieces free, but it takes some time.
+ 1 on the safety glass, I almost got hurt while doing this.
alexisfogel - Réponse
  • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
  • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
  • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
It is ver likely that the glass you are trying to replace is broken, and this is tempered glass therefore it will chatter in many small pieces while you are working on it. Take this safety advice very seriously and protect your eyes!!! The glass pieces fly everywhere. AGAIN: PROTECT YOUR EYES!!!! BE SAFE!!!
McGiord - Réponse
This last statement cannot be underemphasized! I got two shards of very fine glass into my right eye, luckily got them out right away, before reaching for the safety goggles! Later on, I removed them again because working w/ the small parts was easier. Protect your eyes, people!
Lou Bomski -
Just use some scotch wide transparent tape and cover the broken screen BEFORE you start to taking it apart. It will hold all the shards together and nothing will fly around.
Vatevaaa -
I covered the screen in clear packing tape to control glass particles.
I placed the ipad outside in direct afternoon sunlight for an hour and all of the adhesive was softened quite well.....the screen was off in just a few minutes !
John - Réponse
This is a very good idea John, I wish I'd seen this comment before I spent hours picking tiny bits of glass off the glue!
Tom Scott -
Thumbs up for this tip. I left it out in the sun for 15 min only and it worked a treat. I used a razor blade. The plastic tools are next to useless.
olafgoy -
I had some issues after replacing this cable.
Once I had it in and back together only the down volume was working, and shortly after the gyro gave out.
I ended up going to where the new cable connects to the board, removing it, then replacing it as gently as possible. Not too firm.
I also removed a foam spacer in that area because it was pushed out over the gyro board.
Now I'm back to full functionality!
clatekeen - Réponse
me 2 my volumen up doesn't work and the switch sound/silent any fix?
Zadd -
Badly broken screen, taped and warmed about 15 minutes on heating pad set on high. Perfect, gentle, overall warming! Mark the front with Sharpie, ie WiFi, cable, etc. Used thin metal iSes... type tool and guitar pics. BUY NEW Plastic bezel!!! So super cheap. Rewarm on heating pad as necessary. Compressed air helpful to blow away tiny glass bits. Wear glasses! Take breaks! This is easy if you warm carefully and are patient!
Max - Réponse
I am in the process of replacing a shattered screen on an iPad 3 wifi, and I literally was removing glass piece by piece! I do recommend having a roll of wide clear sealing tape at hand. Then, when you see loose glass shards, pull off about 4 to 5 inches, and stick the tape to pick up the loose glass, and once in a while, fold the tape onto itself (sticky to sticky side), and set it aside. This helps keep it from getting everywhere. Also, spread news paper under your work. Some people don't really think of these things, but the fact is, hardened glass will find its way into your skin very easily. Extremely sharp!
dbrown900 - Réponse
Have not attempted this repair on my wife's iPad 2, but is there a reason that you put the iOpener on top of the device rather than putting the device on top of the iOpener? After all, heat rises.
Stephen Weber - Réponse
  • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
  • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
  • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
there is the power flex cable near the top right side of the screen. It could be damaged is not careful.
ChiangFeng Li - Réponse
Yes, I severed this one on my first attempt. Might note that you want to start prying open below the sound controls. Additionally I found that a razor was helpful in getting the first pic into the device. Obviously you want to be careful as a razor could cause some serious damage, but I just used the tip of the metal to get some space to fit a pick.
Nick Dresang - Réponse
Maybe I was doing it wrong, but the plastic opening tool I was using kept bending before it was prying anything apart. Therefore I suggest using either a metal spudger or a razor blade to make the very first opening but being VERY careful. My assistant/wife later scratched the LCD going overboard with the metal tools.
Logan Kennedy - Réponse
There is a way of making the Wifi/Bluetooth Antenna replacement much easier. If you have a steady hand and a soldering iron simply desolder the connecting cable from the bottom of the antenna and solder it back onto the new antenna. This means there is no need to dismantle the iPad and the repair is much faster. Hope this helps :-)
Richard - Réponse
The process was pretty straightforward, you do need to be careful in a few spots (like the wifi antenna in the lower right) but overall I found it to be of medium level of difficulty.
It took me 2.5hrs to slowly dismantle and replace the broken screen.
Here are some tips I learned while doing it:
- instead of plastic spudger, better to use kit knife or razor blade. I found plastic to bend and malform quite easily.
- watch out for lower right corner where wifi antenna sits, it's easy to damage it
- if you have a cracked screen, use protective goggles - i used tape to secure broken glass pieces together, but that didn't quite work and lots of glass was flying as I was prying the screen off the ipad
- opening tool you put in the microwave sold here is not worth it - didn't do that great for me. I mostly used a hair drier and was very successful melting adhesive
- tools I'd only need again to do it again - guitar picks, kit knife, phillips screwdriver, hair drier :D
Overall, I found it to be quite interesting project!
michalmotykiewicz - Réponse
Seconding the problem about plastic components. They just aren't strong / precise enough to fight this glass. Save them for the really nasty bits like the wifi cable, and use an X-Acto or equivalent everywhere else.
Golden Neckbeard -
Wish I would have seen your comment before I went through it. Switched to a razor blade and that helped for sure. Thought about a hair dryer as well but stuck with the micro heating tool. Probably should have done the dryer. :-/
Josh West -
Had much more success using the metal spudger versus the plastic opening tool that came with the front panel kit.
Paul Boyer - Réponse
I had success using Paddle Pop sticks instead of guitar picks. (not sure what they are called in the US). The guitar picks tended to deform and melt with the heat of my hot gun. The glue used to attach the screen is just amazingly strong! It takes a lot of patience to remove all the fragments. I have done about 6 screens now and it is a turdful job!
Jack - Réponse
I think we call those popsicle sticks. They seem kind of thick for this, at least a lot thicker than a guitar pick.
John -
It is not glue, they use a very strong double sided 3M tape
Odus182 -
Pay attention to the Power Button cable located in the upper right corner !!!
Nathan - Réponse
Successful battery change but I did sever the cord/ribbon to the power/sleep button. As my iPad had been opened before at a repair shop, I think they put adhesive over the cord as the small section was stuck underneath the LCD, barely visible. So be careful not to put adhesive above that exposed ribbon/cord to the power/sleep button or the next time you open it up, it's severed.
Breadman - Réponse
On the iPad 2 I repaired, the opening started at 1 inch and ended at 3mm.
Justin H - Réponse
Like others i found the plastic tool pretty useless. Exacto, razor blade, or small metal pick/pry tool works much better to get that first guitar pick inserted. Be careful not to damage the bezel too much. Unless to plan to replace it.
B Kirkham - Réponse
If you have an iPAD that has been repaired before note that the adhesive strip might not have an opening by the volume control as shown. I replaced the glass and the new glass had a 2" gap to the left of the Home button only.
winwoodc - Réponse
The glass is much thinner than you'd think and I broke mine trying to lever it off before the adhesive has softened enough. Be VERY gentle!
winwoodc - Réponse
My plastic opening tool broke in no time flat. Perhaps I was pressing down too hard and not wiggling it enough. But for me I found that the metal spudger was the best tool for the job. I was able to wiggle it while slowly prying up the glass and once it was under the surface of the glass I was able to work it along the edge quite easily. I saw that some people used a razor blade but I would be afraid the blade would break. The metal spudger was just thin enough to do the job well.
  • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
This visual is helpful. It would be great also to have a diagram of the top of the ipad, marked with "top," "bottom," "left," "right," and then an arrow pointing to each of the problematic areas, such as wifi cable, digitizer cable, etc. It would be easier to see the whole schematic while working rather than scrolling through the instructions and trying to visualize each piece separately. Good to see where to be careful...
Christa - Réponse
  • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
My screen was too broken for this "heat, cut with picks, and leave in place" method to work anywhere but the top, where it was essentially undamaged.
I wound up using a spudger through all the cracked sections to pry upwards just *inside* the perimeter of the adhesive, intentionally breaking the digitizer and the glass further, until I could remove the entire front panel except for the adhered portions - about half the perimeter in my case.
I then used tools to pry up the glass from the *opposite* direction, that is the broken interior edge I had earlier created, thus not having to fight the bezel and also having a clear line of sight to any interior components I might be damaging.
Of course, doing it this way made it much easier to drop tiny shards of glass all over the interior, but I found a little diligent cleaning much easier than trying to keep the glass intact while breaking the glue, as in this guide.
Golden Neckbeard - Réponse
I found that using a scraper blade was the easiest way to get under the glass, both for broken and unbroken areas.
Jeff Snider - Réponse
  • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
It should be noted that the glass can be much more difficult to remove when it is cracked and shattered (as is usually the reason for replacement) . Depending on the location and severity of the cracks, the order and technique of removal requires modification.
I have found that putting a layer of clear packing tape over the entire screen is helpful, wether it's cracked or not. It will prevent the spraying of glass shards, should the glass break while separating the adhesive; with a broken screen, it should eliminate the risk of cutting yourself during removal, as well as hold all the pieces together. Unfortunately, it also makes the iOpener slightly less effective, so peel it back when applying it. Suction cups can also be helpful during final removal of the glass.
Having a hot air gun/pencil can be helpful in removing smaller pieces if broken glass that remain once the bulk of it is removed.
Nick V - Réponse
Just trashed an I pad... Not an electronics person. Did an iphone 5 battery with no problems was following instructions and once I hit the next step I realized I had already screwed up the screen... Moving forward tring to unhook LCD pictures are not very clear on which direction to push or pull so broke that... Now writing a review on it... Take it to a pro if you aren't certain!
rondiedonelson - Réponse
I found that the adhesive could be separated when the pick or spudger was in at a depth of between 1/4" (6.4 mm) and 3/8" (9.5 mm). You can always go back and work it in deeper if you are having trouble separating.
Yoh but this is not so simple of your screen is shattered to the edges. Basically I had to lift, shatter more, and then pick off the splintered glass with tweezers bit by bit. Patience is a virtue here. I gave up on saving the adhesive and used it to help remove the splinters. I basically removed the edges of the iPad like that and then lift glass off. WEAR SAFETY GLASSES. I would be blind now if I didn’t. wifi antenna -Go slow make sure it’s hot +check what you are doing in the crack. Remove all splinters fromiPad when it’s open. Clean LCD with a microfibre cloth and inside of your new digitizer. When I first reassembled, the home button didn’t work. I reopened and made sure the two gold connectors align with the two spikes on the body. I placed the home button board face down onto the connector spikes with adhesive on the other side, then lowered the digitiser onto it so the board would stick to the digitiser. Notes: forget plastic spudger they’re only place holders, I used a blade knife and metal Spudgers
Sarah Pegden - Réponse
  • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
I have found that its better to put more than one pick down the side of the screen to keep it open and prevent it from sticking back down.
Roberto Enrieu - Réponse
  • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
  • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
  • The adhesive is very strong, and some serious force may be required. Work carefully.
  • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
Ajouter un commentaire
  • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
  • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
The volume power button cable is really close to the edge and is frequently loose and non adherent to the frame. If your pick is deep into the iPad, you are almost sure to cut the cable. Be very cautious around the top right corner of the iPad.
silvain1038 - Réponse
I absolutely severed this cable when loosening the adhesive around the volume button area. There is really no way of knowing if this cable somewhat elevated from the frame and therefore susceptible to being cut, and it happens to be right where one starts to remove the face with the guitar picks. The cable is directly in from the down volume button, so be extra careful not to put the guitar pick in too far in this area. I recommend buying a power/volume button cable just in case. Replacing this cable is also not easy, but doable. Just try to avoid doing it.
nickmalmquist - Réponse
Why not work in reverse to the top edge, and back around to the area where that cable may be unsecured? Haven't don't an iPad (yet, staring one in the face right now) but that would be my alternative so the screen is mostly loose and you could possibly see the cable looking from the now open left side of the glass?
Matt Needham - Réponse
  • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
  • Re-heat the iOpener, and move it to the top edge of the iPad.
  • The next few steps require extreme caution.
  • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
  • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
I cut through my wifi cable partially, but it still works (surprisingly). I'd recommend staying well clear of this with the pick. When you go to lift the screen (future step, NOT NOW), use a really good light, start to lift the glass slightly at the corner and you will be able to see the cable. Then you can heat it more and watch the cable as you pull through the adhesive there making sure your not catching the cable.
B Kirkham - Réponse
If you heat the sides and top, releasing the adhesive, you can peel the broken glass front panel up from the body and with a little force the bottom comes loose. This avoids working around and damaging the Wi-Fi Antennae.
Michael Vovaris - Réponse
I know it is hard to tell from the photo, but the Wi-Fi antenna is kind of like a flap that opens on the right and is attached on the left. So if you use a pick to slide from right to left, the pick might slide under the flap and then sever how it is attached. When I had my pick just to the right of where the Wi-Fi antenna is, I was able to twist my pick a little (like you are tightening a screw) and pry the screen up where the antenna is located. Then I just moved my pick to the left of the antenna and could continue loosening the screen.
Irreversible damage to the Wi-Fi antenna is nearly unavoidable, but this is not the end of the world since you can pick up a perfectly fine replacement on-line for a few bucks. Many digitizer screen replacement kits include a new WiFi antenna and new bezel since removing the screen without damage to these is also nearly impossible. If your iPad is old enough to need a new battery, and you plan on keeping it thru at least another battery's expected life span, then I would plan on replacing the digitizer screen, bezel, and WiFi antenna as part of the battery replacement. The battery is going to be the most expensive of the set, say around $15 (US), and adding the other three will only add about another $15 (check the prices in ebay, amazon, etc.). Removing the screen often results in damage to the on/off and volume control cable since it too runs along the upper right hand edge of the base right under the screen. If you cut thru this then add another $1 to replace it too.
Jerry - Réponse
Based on my experience just (nearly) completing this job on an iPad 2, CDMA, is that the trickiest step is reconnecting the three CDMA antenna cables on the underside of the CDMA chip that is part of the logic board assembly. These are nearly microscopic button connectors (maybe 0.5 mm in diameter). I needed 8X magnification glasses, very bright light, tweezers, and incredible luck to get these reattached. They pop off no problem, but getting them positioned to apply pop-on force takes a LOT of patients! Maybe someone knows a trick to doing this? There’s a similar connector on the WiFi cable but the chip it attaches to can be removed from the logic board so you’re able to manage positioning them interdependently. The CDMA chip is attached (soldered?) to the logic board and the three button connectors are on the underside, and pretty close to one another, so getting all THREE attached and then the logic board in place is a miracle.
Jerry - Réponse
  • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
  • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
Be sure to have a replacement Bluetooth Wi-Fi antenna because it is very likely to get the cable broken at this step.
McGiord - Réponse
Be extremely careful and patient at this step. Proceed slowly with only the tip ( 1/16th in. - 2mm max.) of the pick. There are two tinny screws that attach the bottom of the antenna to the iPad frame. This antenna part is easly severed if the pick goes too far.
Happenned to me and had to replace the antenna.
Marc Bouchard - Réponse
  • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
  • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" of the tip is still under the front glass.
  • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
I nearly broke my wifi antenna because I didn't read this whole step clearly and didn't go backwards and release the antenna from the front panel. Admittedly, this is my own fault but I've edited the step to make this point more clear.
My screen was way too shattered for me to be able to use the screen instructions as suggested, so I followed the general principal but ignored the order around, because that simply wouldn't have worked...and destroyed the antenna.
Maybe step one should be "BE CAREFUL IN THIS CORNER OR YOU WILL BREAK THE ANTENNA!" A diagram highlighting where all the cables (antenna, digitiser, volume, toggle switch) lie with the screen still attached would be helpful too.
HRB - Réponse
Or maybe you should have read the entire thing before starting if you were not planing on following it step by step
Hawesg Garrett -
I Broke my antenna like many others. It is glued to the glass and has 1mm thick foam backing that is also glued to the inner case. Then there is a tiny grounding connector screwed at the lower edge of the case. Once you can get things loosened up around this antenna, you will need to detach this antenna from the glass. Work at it with your picks or spudger until you get it free, if you do not get it to release from the glass you will break the grounding ribbon. I bought a cheap aftermarket antenna on amazon for $3. turns out it has a bad cable coming from it. I was able to unsolder the cable from the one I broke and solder it to the new antenna.
chrisnewitt - Réponse
This BEGS for an Archer "Just The Tip" reference.
Christian - Réponse
It wasn't obvious to me at first that I'd broken the antenna. A picture of the antenna that works compared with one that is broken would be useful. Fortunately I'd ordered the replacement part just in case, as suggested.
I think using extra heat on this spot may make it easier to unstick without breaking the antenna?
A diagram of what the antenna looks like, from the side, would make it clearer what to do with the pick. You are trying to detach the antenna from the glass, without ripping it off where it's screwed into the bottom of the ipad. Since you can't see what you are doing, and the antenna is quite fragile, that's tricky.
I think once you've broken one you would know better how to do it. When you slide the pick to the right you need to be sure the pick is moving above the antenna and not snagging on it in any way, and you need to be sure the antenna is completely detached from the glass, so you don't tear it when you lift the glass up.
Chris Jordan - Réponse
Can anybody give me a clue as to what the exact part is in step 57, As there are slightly different cables for the ipad 2, Mine is A1395, Thanks.
Jasper - Réponse
  • Once you have moved past the Wi-FI antenna (approximately 3" from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
  • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
Be extremely cautious on this step! I did it wrong and my antenna went to !@#$.
Lars Lien Ankile - Réponse
Also once it is unattached from the front panel, if the antennas adhesive touches the glass again it can re-adhere to front panel and may rip apart after all. Keep a close eye on it or leave a pick or card in there to prevent it from re-sticking.
Danny Hartley - Réponse
  • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch once the pick is past the home button.
  • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
  • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
  • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch in this area, to avoid damaging the home button ribbon cable.
  • Leave the opening pick wedged underneath the front glass near the home button.
This should include details about the Home Button Ribbon Cable. Unlike an iPad 3 (which doesn't have this cable) the iPad 4 has a Home Button Ribbon Cable that runs along the left side of the Home Button and is adhered to the glass. If the guitar pick is inserted too far (more than 0.5") it is possible to damage or sever this cable.
robjpete - Réponse
There is a reason this is an iPad 2 Wi-Fi EMC-2560 repair guide. This guide isn't for iPad 3 or 4...
Christian -
I think the guides carry common steps between them. I'm reading this string of comments on multiple ipad 3/4 repair guides.
Anticept - Réponse
Can I suggest putting the warning in red at the top of the instruction rather than half-way through it? I work from these guides by scrolling through them as I go, and I'd already put the spudger through the ribbon cable before I read the warning!
spl23 - Réponse
  • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
  • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
  • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
  • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
  • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
In my case I damaged the right GSM antenna which was somehow sticked to the front panel... Be really careful as I really didn't felt that I was damaging anything...
MattLise Gaillzik - Réponse
+1 on the right 3g antenna - it is adhered to the glass and I cut right through it with the opening pick. The replacement included adhesive to re-stick it to the glass, so this is a definite feature of this antenna. This is a thin film similar to the wifi antenna, so maybe going around it at a shallow depth from the corner to the camera and then returning to the corner slightly deeper would allow you to separate the antenna from the glass without damaging it.
doog - Réponse
Be very careful when going around the front camera, I cracked my screen by prying up too much and causing too much stress!
Rowdydtk - Réponse
The GSM component is glued to the screen with different adhesive (more like glue). I managed to not damage this but it was really tricky. The guitar pick is too thick and weak to release this from the screen. Id recommend you wait until you lift the glass (future step, NOT NOW). Then, with a good light you'll see the white plastic adhered to the glass. A thin metal pick or exacto is needed to patiently cut & pry your way through the adhesive. Careful of the camera as your pulling in that direction.
B Kirkham - Réponse
  • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
  • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
  • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) to prevent damaging the digitizer.
  • The digitizer cable is located approximately 2" from the bottom of the iPad. Stop sliding the pick when you get ~2.25" from the bottom of the iPad.
The second photo does not show the iPad 4's Home Button Ribbon Cable.
robjpete - Réponse
Because this is for an iPad 2
Odus182 -
@odus182 It says clear as day that this is an iPad 4 guide!
Mike Enos -
This is the hardest part the digitizer cable runs the length of this side and u have to be very carefull with the pick . Only go in an 1/8 inch I severed it by going the half (recommended) luckily I had a new screen standing by . I used I opener for heating and it was slow but ok.
wperrin623 - Réponse
How do i fix my digitiser if it's broken? Do i need to buy a new iPad screen with digitiser?
Jenny Le - Réponse
just ruined my digitiser..any ideas how to fix it?
dleimonis -
There is an error in the red text in this step. It says ‘The digitizer cable is located approximately 2" from the bottom of the iPad’. The next sentence says .. ‘Stop sliding the pick when you get ~2.25" from the bottom of the iPad.. This will slice and ruin that cable. The last sentence should read ‘Stop sliding the pick when you get ~1.75" from the bottom of the iPad.’ so you stop cutting glue before you get to the digitizer cable.
@Jenny & @dleimonis - you can buy the digitizer and new cable by itself if you do not need an LCD also. They are separate parts.
Jon Lucenius - Réponse
  • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
  • The bottom of the digitizer cable is only ~1" from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
If your screen is broken or shattered there are no worries with the digitizer cable, It is all on the new screen.
Exactly. I purposely severed mine as it was a complete screen replacement and made the LCD removal easier.
  • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
  • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
Should be right-hand corner
longg - Réponse
Be very careful when pushing the guitar pick around the corner of the power/volume buttons. The ribbon cable for these buttons may be stuck to the adhesive and break when lifting the screen or when sliding the pick along this area. I have done 4 iPad 2 repairs and at least one of the delicate components do not make it. I would recommend ordering a wi-fi/bluetooth antenna, bezel with strips, and a power/volume cable. It is nice to have a "just-in-case" part or two, they are very inexpensive. I noticed that the I tended to break one of these delicate components when the screen was shattered in the area of those components.
thetechandtutor - Réponse
At this point it is a good idea to get the packing tape back out and wrap it around 2 or 3 of your fingers making a circle with the sticky on the outside. Make it loose enough you can place your fingers on the table surface to the side and pull your fingers out. When you remove all the tiny parts/screws in the next steps put them on top of the tape so you know exactly where they are when you need them
windizy - Réponse
  • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
  • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
Check to the right of the Home button to see if the wifi/bluetooth antenna is still stuck to the glass side or has released. If it is still stuck to the glass use the guitar pick to carefully scrape it off. If your goal is to replace the antenna, then you needn't be so careful.
jerry81 - Réponse
Be very careful not to touch the LCD. It's a pain to remove smudges. One thing that might help when you need to hold it while reattaching it during reassembly: attach a small suction cup to the metal side. That way you can avoid touching the sides where your hand might slip to the LCD side.
patjmccarthy - Réponse
Do you need to use some adhesive strips to remount the plastic bezel? The bezel I ordered didn't come with any and the ones you can order only seem to have strips for mounting the glass and not the bezel.
James - Réponse
You'd better. The original bezel is glued. You can find 3mm fine/double-sided (black) tape on Amazon. I use it when I replace the bezel because they fit perfectly under the bezel. I use for all sorts of repairs on iPhones, Samsungs, etc. Such as this [one|http://www.amazon.com/gp/product/B005GIS...]
Rany -
In order to prevent touching the LCD screen with your finger(s), I use the thin plastic food wrapper to cover it. It will temporary stick to the LCD screen and provide excellent protection from fingerprints.
Th Th - Réponse
Very good suggestion. It worked like a charm.
Laurie Higgins -
you can use latex gloves to keep smudges and finger prints from the screen. I'm getting ready to repair mine, thanks for all the comments and tips. Btw, I wonder if a vacuum cleaner would work for removing small pieces of glass.
De Dios sept.10 2014
dediosjon - Réponse
where is the connecotr for home button at the ipad 3....i have nothin where i can plug in the flex cable comin from the button
Georg Heinze - Réponse
Go slowly as you lift up the glass and be sure that you are not tearing a ribbon cable. When I lifted the glass the digitizer cable was torn and unusable. Perhaps I had cut it with the pick/spudger but it tore completely off when I lifted the glass. Good thing I had purchased the full front panel assembly with the digitizer (IF116-018-3).
When reassembling I used canned air to blow off dust on the LCD before closing it up.
You can use a clean soft brush like a make-up brush or small paint brush to brush off the LCD.
I like how the pictures show an intact screen being removed (although the one in step 4 has a couple of cracks in). I don’t know if anyone would have the luxury of being able to remove a screen in one piece, the ipads I've fixed have been completely smashed pretty much all the way around the outside of the lcd underneath. I used this guide to know where to watch for cables etc - very helpful. I end up using a window scraper/razor to scrape off the glass shards/adhesive around the edge. Glass shards/dust all over the lcd is easy enough to get off but cleaning the lcd after that is a real pain. Does anyone have any suggestions how to clean the lcd properly?
jmzaj - Réponse
  • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
  • The bottom left screw is obscured by the home button ribbon cable connector. Carefully move the home button ribbon cable aside to remove the bottom left screw.
The 00 bit didn't fit my screws. Needed to use the 000 bit.
David Siebecker - Réponse
  • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
  • Rotate the LCD along its left edge and lay it down on top of the front glass panel.
  • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
  • Using the tip of a spudger, peel back the piece of tape covering the LCD ribbon cable connector.
This should be the point where you disconnect/isolate the battery.
Jacob Beranek - Réponse
I see there is a battery isolator in the iOpener kit but they don’t mention using it here. I didn’t isolate the battery on my last fix and didn’t have an issue - maybe I was just lucky. Will try to remember to do it in future.
jmzaj - Réponse
  • Flip up the retaining flap on the LCD ribbon cable ZIF connector.
  • Using your fingers or a pair of tweezers, pull the LCD ribbon cable from its socket on the logic board.
The cable SLIDES toward the edge - NOT lifts out!!! My iPad is damaged where I must now sell for parts - instructions are NOT specific about the cable SLIDING - photo appears that it LIFTS out!!!!
samattie - Réponse
Thank you yes sliding the cable out worked great.
Patrick Gross - Réponse
IMPORTANT NOTE. you MUST disconnect the battery before disconnecting the LCD, or you risk blowing out the back light. This is a basic step for any device, disconnect the battery for you disconnect ANYTHING else.
Thomas Gehman - Réponse
God.... why didn't I check these comments first?!?! Just had the same problem as samattie. Instructions said 'pull it from its socket', included a picture that kinda looked like it had been pulled upwards, and (unlike other less-fragile dangers) did not include any warning of a danger to be careful of. Now, after 1 mistake, even though I didnt use hardly any force at all, the cover flap to the zif connector is broken, and some of the pins are bent or missing (a single sneeze is probably enough to bend them, an they dont even need that much to fall out if exposed)... so all this effort was a total failure. Next I can tell my 9 yr old son I wasn't able to help him fix the ipad he accidentally dropped. Think he'll be happy if I give him an etch-a-sketch instead?
I know its nobodys fault but my own... but especially now, knowing this was pointed out 2 years ago but still left from the guide.... all I can say is FU too. This will be the first and last time I ever try and use this junk site.
O Marrow - Réponse
The instructions are not clear and there is an assumption that you should know the cable slide out to the left. Closely inspecting the connector with good light or inspecting the replacement parts should make this very clear. If you are obliviously working you might mess it up. If you are paying attention at all this is an easy task.
Big Tom - Réponse
  • Without touching the front of the LCD, lift the LCD off the front panel.
  • If present, remove the piece of electrical tape covering the Wi-Fi antenna, speaker cable, and home button ribbon cable.
I recommend disconnecting the cable at the home button and leaving it attached here. It is a challenge to get it back in,
Joel Mann - Réponse
  • Flip up the retaining flap on the home button ribbon cable ZIF connector.
  • Use a pair of tweezers to pull the home button ribbon cable straight out of its socket on the logic board.
It helps quite a bit to peel the black plastic block off the aluminum case to give you the room to work with the home button cable on reassembly. Lean the new digitizer against something so it's at a 90 degree angle to the bottom case to help line up the cable connector to the ZIF socket. Use the tweezers on either side of the "neck" of the cable to encourage it back into the ZIF socket; it doesn't require too much force.
Boz Duffield - Réponse
Instead of disconnecting the cable here, Take out the two screws on the home button and remove it there, Re-installing this cable is a challenge. The adhesive is gently peeled away under the cable near the home button.
Joel Mann - Réponse
  • De-route the home button ribbon cable from its recess in the rear case.
  • Use a pair of tweezers to peel back the piece of tape that secures the digitizer ribbon cable to the logic board.
At this point you really should disconnect and isolate the battery before unplugging any cables.
  • Flip up the retaining flap on both of the digitizer ribbon cable ZIF connectors.
  • Use the flat end of a spudger to loosen the adhesive underneath the digitizer ribbon cable.
  • Pull the digitizer ribbon cable straight out of its sockets on the logic board.
  • Peel back the digitizer ribbon cable and use the flat end of a spudger to release the adhesive securing the cable to the rear aluminum case.
  • Using your fingers, pull the digitizer ribbon cable out of its recess in the aluminum frame.
  • Remove the front panel from the iPad.
  • Use tweezers to peel back and remove the piece of electrical tape covering the headphone jack assembly cable connector.
  • Using the tip of a spudger, flip up the retaining flap on both of the ZIF connectors securing the headphone jack cable to the logic board.
  • Slide the flat end of a spudger underneath the headphone jack assembly cable, releasing the adhesive securing it to the rear aluminum frame.
  • Pull the headphone jack assembly cable straight out of its socket on the logic board.
  • Carefully move, but do not remove the front-facing camera ribbon cable aside with the flat edge of a spudger.
  • Peel back and remove the adhesive tape covering the headphone jack assembly.
  • Using the tip of the spudger, flip up the retaining flap on the microphone cable ZIF connector.
  • Insert the tip of the spudger underneath the microphone ribbon cable and carefully push it out from its socket on the ZIF connector.
  • Use the flat edge of a spudger to move the microphone ribbon cable aside.
  • Flip up the retaining flap securing the volume/power button ribbon cable connector to the headphone jack assembly board.
  • Push the volume button ribbon cable from its ZIF connector.
  • Gently bend the volume button ribbon cable upwards to move it aside.
  • Remove the following screws from the headphone jack assembly:
    • Five 2.6 mm Phillips #0
    • Two 2.2 mm Wide Head Phillips #00
    • Two 2.6 mm Phillips #00
      • These screws are angled into the aluminum frame. Be sure to hold the screwdriver so that the screwdriver is in line with the screw, to avoid stripping the screw.
  • Holding onto the ribbon cable of the headphone jack assembly, carefully pull the assembly upwards towards the top of the device.
  • Grasping the headphone jack assembly with one hand, pull the assembly from the iPad, minding any cables that may get caught.
  • Remove the following screws securing the power & volume button cable to the aluminum frame:
    • Two 5.5 mm Phillips #0
    • One 2.6 mm Phillips #0
  • The two screws located on top are angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  • Remove the piece of plastic covering the volume buttons.
  • Remove the single 2.6 mm Phillips #00 screw holding the volume button frame to the aluminum frame.
  • This screw is angled into the aluminum frame. Be sure to always hold the screwdriver in line with the screw.
  • Wedge the edge of a plastic opening tool underneath the sleep/wake sensor, being careful to not damage the fragile cable.
  • Move the plastic opening tool around the sensor, releasing the adhesive.
  • Slide the tip of a spudger underneath the power & volume cables, releasing the adhesive.
  • Using the tip of the spudger rather that the wide edge, release the adhesive underneath the volume button branch of the ribbon cable.
  • Continue sliding the tip of the spudger toward the top of the iPad, releasing the adhesive.
  • With the tip of the spudger still underneath the ribbon cable, gently lift the power button out of its socket in the aluminum frame.
  • Lift and remove the power & volume button cable out of the iPad.
  • Wedge the tip of the plastic opening tool underneath the top side of the power button.
  • Pry the topside of the power button up off the power button bracket.
  • Repeat the previous step on the underside of the power button.
  • Lift and remove the power button bracket from the power & volume button assembly.
  • Wedge the tip of the plastic opening tool underneath the top side of the rotation lock/mute switch.
  • Slide the plastic opening tool downwards to pry the topside of the rotation lock/mute switch from its bracket.
  • Insert the tip of the plastic opening tool underneath the top volume rocker and pry upwards to separate it from the volume buttons bracket.
  • Repeat the procedure to separate the bottom volume rocker from the volume buttons bracket.
  • Lift and remove the power & volume button ribbon cable.
To reassemble your device, follow these directions in reverse and use our iPad 4 Wi-Fi Front Panel Adhesive strips guide to reattach the front panel.
7 autre(s) ont terminé cette réparation.
The following steps can be skipped:
31-46
49a,c
50-51
Mike Hayeck - Réponse
Voir les statistiques:
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 42
Total : 4,443
