Aller au contenu principal
iPad Air 3 Screen Replacement
Ce dont vous avez besoin
  1. iPad Air 3 Screen Replacement, Screen: étape 1, image 1 de 2 iPad Air 3 Screen Replacement, Screen: étape 1, image 2 de 2
    • Cracked near home button its important to not break home button flex cable
    • Apply heat to the screen! Do NOT SKIP THIS STEP
    • Make sure to turn it off if you can to prevent breaking the backlight filter
    • Pry with splicer around the edges
    • Display cables are on the bottom of screen opening up like an upside-down note pad
  2. iPad Air 3 Screen Replacement: étape 3, image 1 de 1
    • Lift from the top like so
    • Display Cables
  3. iPad Air 3 Screen Replacement: étape 4, image 1 de 3 iPad Air 3 Screen Replacement: étape 4, image 2 de 3 iPad Air 3 Screen Replacement: étape 4, image 3 de 3
    • Set screen up a little bit to get to power connection
    • Power connection has PH000 screw holding it together
    • Slide a card under connection
    • Its very important to disconnect battery try turning it on make sure it is off to avoid further damage to ipad
  4. iPad Air 3 Screen Replacement: étape 5, image 1 de 2 iPad Air 3 Screen Replacement: étape 5, image 2 de 2
    • Lift display back up to get to the display cables
    • Unscrew 2 PH000 Screws from display cable bracket
    • Use the flat end of plastic spudger to lift off connections
    • There is 4 flex cables that need disconnecting
  5. iPad Air 3 Screen Replacement: étape 6, image 1 de 3 iPad Air 3 Screen Replacement: étape 6, image 2 de 3 iPad Air 3 Screen Replacement: étape 6, image 3 de 3
    • Whoohoo we got it off now clean the edges for any broken glass
    • Keep track of rubbers covering proximity light sensor on the top
    • Light covers place on top of proxmity sensors
  6. iPad Air 3 Screen Replacement: étape 7, image 1 de 3 iPad Air 3 Screen Replacement: étape 7, image 2 de 3 iPad Air 3 Screen Replacement: étape 7, image 3 de 3
    • APPLY HEAT TO HOME BUTTON 15-20 Seconds should do the trick
    • If heat is not applied you might break the home button along with the touch ID. If you replace the home button touch ID will not work anymore
    • Take of home button flex cover
    • Use flat end of spudger to pry up home button flex connector
  7. iPad Air 3 Screen Replacement: étape 8, image 1 de 3 iPad Air 3 Screen Replacement: étape 8, image 2 de 3 iPad Air 3 Screen Replacement: étape 8, image 3 de 3
    • Reapply heat if you spent to much time getting flex unhooked
    • Pry with splicer under the home button bracket car
    • Clean glass around gasket
  8. iPad Air 3 Screen Replacement: étape 9, image 1 de 2 iPad Air 3 Screen Replacement: étape 9, image 2 de 2
    • Install home button on new screen I recommend using liquid adhesive for this!
    • Push the home button a couple of times to make sure it stills on and make sure it is clicking!
  9. iPad Air 3 Screen Replacement: étape 10, image 1 de 2 iPad Air 3 Screen Replacement: étape 10, image 2 de 2
    • Connect all 4 Flex cables to the logic board!
    • Now at the bottom of the new screen screw in the battery connection to test the new screen!
  10. iPad Air 3 Screen Replacement: étape 11, image 1 de 1
    • Test screen drawing on the notes make sure it works!
    • Adhere new screen with preinstalled adhesive and clap it!
Ligne d'arrivée
2 autres ont terminé cette réparation.
Mark D Schlossman
Membre depuis le 09/25/19
6 462 Réputation
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 112
Total : 2,072
