Introduction
Utilisez ce tutoriel pour remplacer la caméra frontale.
Nous recommandons de nettoyer le micro-ondes avant de commencer. D'éventuels restes au fond risquent d'adhérer à votre iOpener.
  • Nous recommandons de nettoyer le micro-ondes avant de commencer. D'éventuels restes au fond risquent d'adhérer à votre iOpener.
  • Placez l'iOpener au centre du micro-ondes.
    • Pour les micro-ondes à plateau tournant : assurez-vous que le plateau tourne bien. Si votre iOpener se coince, il risque de surchauffer et de brûler.
which temperature must be used for heating? Thx
fbarletta - Réponse
I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
Fredrik -
I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
windizy - Réponse
I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
Martin Gray - Réponse
I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
Jan Van Puymbroeck - Réponse
Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
Fletcher Carpenter - Réponse
I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
putinaspiliponis - Réponse
I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
Laurie Higgins - Réponse
Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
Yousef Ghalib - Réponse
I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
Sherry Carew - Réponse
Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
Esmond Pitt - Réponse
Hi, the microware have multiple power 1 to 9, what must be used ?
Regards,
Cedric
Cedric VINCENT - Réponse
Chauffez l'iOpener pendant trente secondes.
  • Chauffez l'iOpener pendant trente secondes.
  • Comme l'iOpener refroidit au cours de la réparation, rechauffez-le à nouveau au micro-ondes, mais ne dépassez pas les trente secondes à chaque fois.
  • Faites attention de ne pas surchauffer l'iOpener pendant la réparation. En cas de surchauffe, l'iOpener risque d'exploser.
  • Ne touchez jamais l'iOpener s'il vous paraît gonflé.
  • Si l'iOpener est encore trop chaud au milieu pour le toucher, continuez de l'utiliser jusqu'à ce qu'il ait assez refroidi pour le chauffer à nouveau. Un iOpener correctement chauffé doit rester chaud pendant 10 minutes environ.
May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
yamayhuang - Réponse
I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
whale13 - Réponse
DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
Alex Jackson - Réponse
I don't own a microwave.
mdanihy - Réponse
Its again waterproof when you change iphone 7 battery?
Jon - Réponse
I don't have a microwave???
Joe Blow - Réponse
30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
Sam Stieg - Réponse
can i use just ordinary microwave???
juneseok kwon - Réponse
If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
Mohideen Rifay - Réponse
I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
Travis Dixon - Réponse
There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
assortedrubbish - Réponse
I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
dave - Réponse
If I may suggest include your microwave wattage so people can get an idea on time for there own
Patrick Storey - Réponse
I ended up using a hair dryer. That iOpener thing took forever.
mark fitzgerald - Réponse
30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
60 seconds in the microwave, the iOpener burst.
I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
K
Karl Marble - Réponse
  • Sortez l'iOpener du micro-ondes en le tenant par l'une des deux extrémités plates pour éviter le milieu qui est très chaud.
  • L'iOpener sera très chaud, alors soyez prudent en le manipulant. Utilisez un gant de cuisine si nécessaire.
Will a hair dryer work for heating the glass?
Me berg - Réponse
Yes, as does a heat gun.
anonymous 4602 - Réponse
I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
Cobus de Beer - Réponse
  • Si votre écran est fissuré, et afin de prévenir une nouvelle casse ou une blessure pendant la réparation, recouvrez de ruban adhésif toute la vitre de votre iPad.
  • Placez des bandes superposées de ruban adhésif transparent sur l'écran de l'iPad jusqu'à ce qu'il soit entièrement recouvert.
    • Cela permettra de ne pas faire tomber les éclats de verre et de garder une certaine stabilité lorsque vous ferez levier et enlèverez l'écran.
  • Faites de votre mieux pour suivre le reste du tutoriel tel que décrit. Cependant, une fois que le verre est cassé, il continuera sûrement à craqueler et vous devrez peut-être utiliser un outil en métal pour dégager les éclats de verre.
  • Portez des lunettes de sécurité pour protéger vos yeux et faites attention de ne pas endommager l'écran LCD.
In case of broken glass, here are some hints:
- I prefer 3M "3350" tape; a metalized polypropylene tape with an acrylic adhesive. It's a very thin, silvery HVAC tape, not your standard duct tape.
- Test your tape to make sure it sticks really well to the glass.
- Use isopropyl alcohol on a paper towel to remove fingerprints and other dirt to help the tape stick to the screen.
- Use the widest tape you can find, and apply it evenly, without trapping bubbles, without crinkles: This greatly improves your chance of success with the suction cup later.
- Cut tape pieces long enough and go over the (rounded) edge; afterwards carefully run a scalpel alongside the edge (between bezel and glass) to trim off any excess.
- Don't overlap edges of the tape: butt-join them instead.
- If needed: repeat in other direction.
- If needed: Cut square piece of tape (size of suction cup) and place it where you want to lift the glass, so that the suction cup doesn't cover any butt-joins.
Good luck, you brave person!
volty - Réponse
This is the second broken screen I’ve fixed. Overlapped package tape carefully stuck to the glass and trimmed to the edges will contain most of the shards. I found that a hair dryer works for softening the glue. After getting under an edge with the suction cup I carefully followed the opening sequence using a combination of plastic picks and a single edge razor blade to get under the small pieces. It was slow going with lots of reheating with the dryer (about 45 minutes), but the taped glass came off without glass everywhere.
Bill Roughen - Réponse
  • En le manipulant par le attaches de chaque côté, placez l'iOpener chauffé sur le côté de l'iPad à gauche du bouton home.
  • Laissez l'iOpener agir pendant environ cinq minutes pour ramollir l'adhésif sous le verre.
I worked at it for over 2 hours before deciding to microwave the opener for 45 seconds at a time. That seemed to do the trick.
jaromhyde - Réponse
  • Placez soigneusement une ventouse à mi-hauteur du côté chauffé.
    • Assurez-vous que la ventouse adhère à l'écran sur toute sa surface pour obtenir un joint étanche.
  • Tout en maintenant l'iPad enfoncé d'une main, tirez sur la ventouse pour séparer légèrement la vitre du panneau frontal de la coque arrière.
  • Veillez à soulever le vitre de juste ce qu'il faut pour insérer un médiator, car vous risqueriez de la briser en soulevant trop.
This step is totally pointless if you have a shattered screen. The suction cup is rendered useless. Any tips on what to do if you can't get any suction due to a shattered screen?
robloomis - Réponse
just pick out the glass shards if it is cracked that bad you are better off scrapping the digitizer
Ethan Chow -
for shattered screens I cover the screen with tape. I find packing tape works best for me.
George - Réponse
  • Tout en tenant le verre avec la ventouse, faites glisser la pointe d'un médiator dans l'espace entre la vitre et le reste de l'iPad.
    • N'insérez pas la pointe plus profondément que le cache noir sur le côté de l'écran. Aller trop loin peut endommager l'écran LCD.
  • Tirez sur la ventouse pour ouvrir le joint d'étanchéité sous vide et retirez la ventouse de l'écran.
Ajouter un commentaire
  • Refaites chauffer et Reposez l'iOpener.
    • Veillez à ne pas surchauffer l'iOpener pendant la procédure de réparation. Attendez toujours au moins dix minutes avant de réchauffer l'iOpener.
  • Laissez reposer pendant quelques minutes pour chauffer le bord gauche de l'iPad.
  • Placez un deuxième médiator à côté du premier et faites-le glisser le long de l'iPad, en décollant l'adhésif au fur et à mesure.
  • Si, au long du reste de la procédure, vous rencontrez une grande résistance en faisant glisser vos médiators sous le verre, arrêtez et réchauffez la section sur laquelle vous travaillez. Forcer sur les médiators risque de briser le verre.
  • Continuez à déplacer le médiator vers le bas de l'écran pour détacher l'adhésif.
  • Si le médiator reste bloqué dans l'adhésif, faites-le tourner le long de l'iPad, en continuant à décoller l'adhésif.
  • Prenez le premier médiator que vous avez inséré et faites-le glisser vers le coin supérieur de l'iPad.
  • Si vous pouvez voir la pointe du médiator à travers la vitre, ne paniquez pas, tirez-le juste un peu. Tout se passera certainement bien, mais évitez, car vous pouvez mettre ainsi de l'adhésif sur l'avant de l'écran LCD et c'est difficile à nettoyer.
  • Refaites chauffer l'iOpener et placez-le sur le bord supérieur de l'iPad, sur la caméra frontale.
    • Veillez à ne pas surchauffer l'iOpener pendant la procédure de réparation. Attendez au moins dix minutes avant de réchauffer l'iOpener.
  • Si vous avez un iOpener flexible, vous pouvez le plier pour chauffer le coin supérieur gauche et le bord supérieur en même temps.
  • Faites glisser le médiator autour du coin supérieur gauche de l'iPad pour séparer l'adhésif.
Gezz this is though! Cracked the glass while replacing it.
Padraic Hoselton - Réponse
  • Faites glisser le médiator le long du bord supérieur de l'iPad, en vous arrêtant juste avant d'atteindre la caméra.
  • La troisième image montre l'emplacement de la caméra frontale et de son boîtier dans l'iPad.
    • Évitez de faire glisser le médiator sur la caméra avant, sinon vous risquez de mettre de l'adhésif sur la lentille ou d'endommager la caméra. Les étapes suivantes détaillent la façon d'éviter d'endommager la caméra frontale.
  • Tirez légèrement sur le médiator et faites-le délicatement glisser le long de la zone de la caméra frontale.
  • Laissez le médiator dans l'iPad juste après la caméra frontale.
  • Prenez un deuxième médiator et insérez-le à gauche de la caméra, là où le premier médiator était. Faites-le glisser vers le coin pour décoller complètement tout adhésif restant.
  • Laissez le deuxième médiator en place pour éviter que l'adhésif dans l'angle recolle en refroidissant.
  • Insérez le médiator précédent plus profondément dans l'iPad et faites-le glisser depuis la caméra vers le coin.
  • Laissez les trois médiators dans les coins de l'iPad afin d'empêcher toute nouvelle adhérence de l'adhésif du panneau frontal.
  • Réchauffez l'iOpener et placez-le sur le côté long restant de l'iPad, le long des boutons de volume et de verrouillage.
  • Faites glisser le médiator droit supérieur autour du coin pour décoller complètement le bord supérieur du verre.
  • Laissez ce médiator en place pour éviter que l'adhésif recolle et prenez un nouveau médiator pour l'étape suivante.
  • Insérez un nouveau médiator et faites-le glisser jusqu'au milieu du bord droit de l'iPad, en décollant l'adhésif au fur et à mesure.
  • Continuez à faire glisser le médiator vers le bas de l'iPad, en décollant l'adhésif.
  • Laissez les médiators en place et refaites chauffer l'iOpener.
    • N'oubliez pas de ne pas surchauffer l'iOpener – pas plus d'une fois toutes les dix minutes.
  • Posez l'iOpener chauffé sur la zone du bouton home et laisse-le agir pendant quelques minutes pour ramollir l'adhésif sous le verre.
  • Faites glisser le médiator inférieur gauche vers le coin inférieur gauche pour couper l'adhésif dans ce coin.
  • Laissez-y le médiator. N'allez pas plus loin et ne retirez pas le médiator de l'iPad.
  • Il y a un certain nombre de choses à éviter sous la vitre inférieure, alors étudiez attentivement la troisième image :
    • Antennes
    • Emplacement du bouton home
    • Nappe de la vitre tactile
  • Les étapes suivantes vous diront où il faut travailler pour éviter d'endommager ces composants. Ne faites chauffer que les endroits indiqués.
  • Laissez le médiator de la dernière étape en place pour éviter que l'adhésif recolle.
  • Faites délicatement glisser un nouveau médiator par-dessus l'antenne gauche et arrêtez-vous avent le bouton home.
    • Faites glisser simplement le médiator depuis bord extérieur vers le centre de l'iPad. Ne le déplacez pas vers le bord extérieur, car dans ce sens, vous endommageriez l'antenne.
    • Si vous devez passer plusieurs fois, retirez le médiator et réinsérez-le sur le bord extérieur et faites-le glisser vers l'intérieur.
  • Laisser les médiators en place avant de poursuivre.
  • Insérez la pointe d'un dernier médiator à côté de celui de l'étape précédente et faites-le glisser sous le bouton home.
  • Arrêtez à environ 2,5 cm du côté droit pour éviter de couper la nappe de la vitre tactile.
  • Insérez le médiator un peu plus profondément et retournez vers le bouton home.
  • Encore une fois, assurez-vous de faire seulement glisser le médiator vers le centre de l'iPad lorsqu'il est complètement inséré. Sinon, vous risquez d'endommager l'antenne sous le verre.
  • Réchauffez et reposez l'iOpener sur la partie supérieure du joint de l'iPad.
  • Faites très attention pendant cette étape. Prenez votre temps et assurez-vous que l'adhésif est chaud et mou, et que vous avez coupé tout l'adhésif avec un médiator. N'ayez pas peur d'arrêter et de refaire chauffer.
  • En haut de l'iPad en face du bouton home, vous devriez avoir un médiator logé dans chaque coin. Faites-les pivoter pour soulever légèrement le verre et séparer ainsi le reste d'adhésif le long des quatre bords.
  • Si vous rencontrez une grande résistance, arrêtez de pivoter. Laissez les médiators en place, refaites chauffer et reposez l'iOpener sur les zones problématiques, avant d'y insérer un médiator une fois de plus.
  • Soulevez lentement et délicatement pour détacher l'adhésif le long du bord inférieur.
  • Une fois que tout l'adhésif a été enlevé, tournez la vitre de l'écran comme une page d'un livre et posez-la sur votre plan de travail.
  • Le boîtier de la caméra frontale peut rester accroché au panneau frontal. Décollez le boîtier et placez-le sur la caméra pour la protéger.
  • Faites pivoter le boîtier de la caméra sur un bord pour le libérer de l'adhésif et retirez-le du panneau frontal.
  • Remettez le boîtier de la caméra à sa place dans la coque arrière.
  • De petits morceaux de mousse autocollante recouvrent les vis droites supérieures et inférieures, fixant l'écran LCD à la coque arrière.
  • Utilisez une pincette pour décoller et enlever le morceau rectangulaire de mousse recouvrant la vis supérieure droite du LCD.
  • Retirez le morceau triangulaire de mousse recouvrant la vis inférieure droite du LCD.
  • La vis en haut à gauche du LCD peut être recouverte d'un ruban adhésif venant du panneau frontal.
  • Dans ce cas, utilisez l'extrémité plate d'un spudger pour tirer le ruban vers le haut et à l'extérieur, accédant ainsi à la vis en dessous.
  • Retirez les quatre vis cruciformes #000 de 3,9 mm fixant l'écran LCD à la coque arrière.
In my case the 4 screws are not the same. One is 4mm, and 3 of 3.5mm, or better 2 x 3.5mm and one 3.45mm. I put the longest one at the left edge at left of the LCD flat cable.
mitja
Mitja Jankovic - Réponse
Hi Mitja. I just checked the measurements with an electronic digital caliper. I got 3.9 mm for all four screws. Are you sure it was the same model? Thanks.
Walter Galan -
The top left screw is longer than the other 3 - iPad mini Retina Wi-Fi.
sandro - Réponse
On mine the top right screw is longer
oliver - Réponse
top right is longer on an ipad mini 2 retina wifi 32GB
sagert - Réponse
  • Utilisez une pincette pour décoller le petit morceau de bande adhésive reliant le châssis du LCD au haut-parleur droit.
I wonder what does this sticker stands for…
K8L - Réponse
  • Une mince bande de mousse autocollante sur le cadre du LCD recouvre une bande d'adhésif reliant l'écran LCD au panneau en dessous. Pour continuer, vous devrez déchirer et décoller un peu cette bande de mousse pour accéder à l'adhésif caché en dessous.
  • Utilisez une fine pincette pour tirer le haut de la bande de mousse entourant l'écran LCD.
    • Veillez à ne pas toucher l'écran LCD avec la pincette, car vous risquez de l'endommager.
  • Utilisez la pincette pour décoller le ruban de mousse pour accéder au haut de l'écran LCD.
  • Insérez la pointe d'un spudger entre le châssis du LCD et la bande adhésive sur le dessus de l'écran LCD.
  • Faites glisser le spudger le long de l'espace entre le châssis LCD et la bande adhésive, en décollant la bande du châssis du LCD.
I finished a successful replacement of my screen following these instructions. Thanks.
Step 36 (remove tape from LCD perimeter), however, seems unnecessary. I ended up spending a lot of time separating the tape from the LCD frame only to discover it was not necessary for steps 37-44 and actually made things really difficult for step 45-46 (removing the tape near the speakers). Finally, steps 45-46 can be skipped since it is much easier to remove this tape once you flip the LCD over (Step 55).
Kenneth Snyder - Réponse
  • L'écran LCD est collé à la plaque de protection métallique du LCD, derrière celle-ci, le long des bords supérieur, gauche et droit. Afin de décoller cet adhésif en toute sécurité, vous utiliserez un médiator pour déplacer plusieurs fois l'écran LCD de quelques millimètres de gauche à droite.
  • Insérez un médiator dans l'espace entre l'écran LCD et la coque arrière, près du haut du côté gauche de l'écran LCD.
  • Inclinez légèrement le médiator pour l'éloigner de l'iPad, juste assez pour élargir l'espace entre l'écran LCD et la coque arrière.
I found a very simple method for removing the LCD from the metal shield. Slightly lift one of the top corners and insert a 1' piece of fishing line. Insert the line under the other top corner placing the length between the LCD and shield. Once in place, gently pull each end toward the bottom of the LCD breaking the adhesive as you go. This will make things much easier than using the picks and possibly breaking the LCD.
bababooey - Réponse
The fishing line trick is amazing… although i had already broken the LCD when i saw that comment. Good Learn!
Brandon Lukasik - Réponse
This step is what destroys my LCDs :(
Dan Harris - Réponse
Just destroyed my LCD as well. A red warning remarking is missing here! The LCD assembly is very fragile an cannot be bent, even slightly!!
brauliox - Réponse
  • Insérez le médiator à trois endroits de plus sur le côté gauche de l'écran LCD et inclinez-le à chaque fois, pour faire glisser l'écran LCD sur le côté droit de la coque arrière.
  • Passez maintenant au côté droit de l'écran LCD et faites levier avec le médiator à plusieurs endroits le long du côté pour déplacer l'écran LCD vers la gauche.
  • Répétez cette étape et la précédente plusieurs fois, jusqu'à ce que l'écran LCD soit facilement démontable vers la gauche et vers la droite.
  • Dans les prochaines étapes, vous ferez glisser un spudger entre l'écran LCD et la plaque de protection en métal pour séparer complètement l'écran LCD de l'adhésif en dessous.
  • Insérez l'extrémité plate d'un spudger entre le châssis du LCD et la plaque de protection en métal.
    • Assurez-vous d'insérer le spudger entre le cadre LCD et la plaque de protection, et non sous la plaque. Faire levier sur la plaque l'endommagerait, car elle est vissée à la coque arrière sous l'écran LCD.
  • En commençant en haut à droite de l'appareil, faites glisser le spudger entre le châssis du LCD et la plaque de protection en métal. L'adhésif se décollera au fur et à mesure que vous faites glisser votre outil.
    • L'objectif est de séparer l'adhésif et non de faire levier sur l'écran LCD. Pour cela, maintenez la pointe du spudger aussi bas que possible pour éviter de plier l'écran LCD.
  • Si l'insertion du spudger plie le coin de l'écran LCD, répétez les étapes avec le médiator pour décoller davantage l'adhésif.
These steps were hard. I was too scared that I was going to brake the LCD. Luckily I got it off! Don’t know how delicate these things are and how much force they can take.
  • Répétez la procédure précédente en haut de l'écran LCD.
  • Insérez l'extrémité plate du spudger entre le châssis LCD et la plaque de protection en métal et appuyez doucement sur le haut de l'appareil pour décoller l'adhésif.
  • Continuez du côté gauche de l'écran LCD : insérez l'extrémité plate du spudger entre l'écran LCD et la plaque de protection et faites-le avancer autant que possible.
  • À ce stade, l'écran LCD doit être décollé de l'adhésif qui le retient. Si ce n'est pas le cas, insérez le spudger sur le côté droit ou en haut pour dégager complètement l'écran LCD.
  • Soulevez l'écran LCD à quelques centimètres de la coque arrière pour vous assurer qu'il est exempt d'adhésif.
  • Deux larges bandes d'adhésif relient l'écran LCD aux haut-parleurs.
  • Tout en tenant l'écran LCD d'une main, insérez l'extrémité plate d'un spudger dans l'espace entre l'adhésif et le haut-parleur gauche.
  • Retirez doucement l'écran LCD des haut-parleurs tout en faisant pivoter le spudger vers l'extérieur pour séparer l'adhésif du haut-parleur.
  • Insérez l'extrémité plate du spudger dans l'espace entre le haut-parleur droit et l'adhésif du LCD.
  • Tout en retirant l'écran LCD des haut-parleurs, faites pivoter le spudger vers l'extérieur pour élargir l'espace et décoller l'adhésif du haut-parleur.
  • Retournez l'écran LCD et posez-le sur le dessus de la vitre du panneau frontal.
  • N'essayez pas d'enlever l'écran LCD de l'iPad, car il est toujours connecté par son câble de données.
  • Retirez les vis suivantes, fixant la plaque de protection de l'écran LCD à la coque arrière de l'iPad :
    • Deux vis cruciformes #00 de 2,6 mm
    • Treize vis cruciformes #00 de 2,6 mm
    • Une vis cruciforme #00 de 1,7 mm supplémentaire sur certains modèles
At the iPad mini retina Wi-Fi there are only 7 screws.
sandro - Réponse
On my iPad Mini (Gen 1 WiFi; A1432), these are not #00 screws, but #000 screws. They're much tinier than the first four screws that held the LCD tabs in place. The #00 driver sorta works, but requires a lot of force to get traction. The #000 driver works like a charm, though.
volty - Réponse
On my 1432 there were mixed in 4 tiny #000 screws holding the shield plate aong the right side. Looks like these can be mixed in without consequence as they are shorter anyway
gfriedman99 - Réponse
  • Insérez l'extrémité plate d'un spudger sous la plaque de protection de l'écran LCD, au milieu du côté inférieur de l'iPad.
  • Faites levier avec le spudger pour dégager la plaque des côtés de la coque arrière.
  • Retirez la plaque de protection de l'écran LCD de l'iPad.
  • Retirez les trois vis cruciformes #00 de 1,3 mm fixant le cache du connecteur à la carte mère.
  • Assurez-vous de ne pas substituer ces trois vis par d'autres vis, en particulier les vis qui fixent la plaque de protection de l'écran LCD à la coque arrière de l'iPad. Toute vis légèrement plus longue peut détériorer les trous des vis et endommager irréparablement la carte mère.
Note: These three screws are smaller than the rest of the screws holding the larger LCD shield although they look similar. If you substitute the larger screws, you will pop a screw bracket which can damage the board on both the mini original and mini 2 retina. I just wrote a blog post about how this happens: http://mendonipadrehab.com/entries/gener...
jessabethany - Réponse
Hi jessabethany. Thank you for the warning. I read your blog post and found it to be very informative. Thanks for adding the warning to the step. It will most definitely help others avoid any damage to the logic board. Thanks!
Walter Galan -
Be careful: At iPad mini retina Wi-Fi there are thw short and one longer screw! Don't mix them!
sandro - Réponse
  • Utilisez une pincette pour saisir et retirer de l'iPad le cache du connecteur.
  • Utilisez un outil d'ouverture en plastique pour retirer délicatement le connecteur de batterie de sa prise sur la carte mère.
  • Soyez très prudent de faire levier seulement sur le connecteur de la batterie et non sur la prise elle-même. Vous risquez autrement de briser complètement le connecteur.
Make sure you disconnect the battery. If not and ipad is still on you can have problems with the LCD backlight. To fix that problem you have to solder
Mattis - Réponse
I may be experiencing the backlight problem you mentioned. What connection needs to be soldered?
Grillwrecka -
Have an issue - heard that if you don't disconnect the battery a fuse is blown. I need help to fix the blown fuse.
Andrew Kivell -
There is an extensive thread in Answers about iPad mini backlight problems.Th screen stays black after a digitizer replacement.
jessabethany -
After unplugging the battery place a guitar pick in-between the two connections.
While continuing to work on the iPad you may inadvertently cause the two connections to touch.
Michael Vovaris - Réponse
Yeah, you need to put the pick in between the connections so the battery doesn't touch the logic board connector and blow a fuse and make your backlight not turn on. You really don't want to have to solder the 2 connections together, especially if you don't know how, like me! I will use your comment's advice when working.
WolfyHD - Réponse
I put a piece of cellotape on the contact side of the connector and could happily forget about it while getting on with the rest of the repair.
Rory Filer - Réponse
  • Utilisez un outil d'ouverture en plastique pour retirer le connecteur LCD de sa prise sur la carte mère.
  • Ne faites pas levier contre le grand IC à côté du connecteur, vous risqueriez de le casser. Faites délicatement levier sur côté du connecteur comme sur la photo.
Putting the iPad back together: While plugging the LCD Connector back in, take your time finding the socket on the logic board. Do no use pressure until you are certain it is seated properly. Trust me, if you take your time you will know its seated correctly.
  • L'écran LCD est toujours connecté au reste de l'iPad par deux larges bandes de ruban adhésif qui passent de l'intérieur de la coque arrière à la partie avant du cadre LCD.
  • Tout en tenant l'écran LCD d'une seule main, insérez l'extrémité plate d'un spudger entre l'écran LCD et la bande adhésive sur le côté droit de l'iPad.
  • Faites glisser le spudger vers l'extérieur, en décollant la bande adhésive et en soulevant doucement l'écran LCD pour les décoller.
  • Il peut être utile de faire pivoter le spudger, pour agrandir l'écart et décoller l'écran LCD de la bande adhésive.
Removing this tape and such to take the LCD off completely is unneccessary when replacing just the glass and digitizer, the digitizer cable is easily removed without further work to the LCD
Nick Hughes - Réponse
When this tape damage, how we can take a new?
Muhammed Kilic - Réponse
When this tape are damage, how we can order and take a new one?
Following from Nick H’s comment about LCD removal being unnecessary - I tried that first and got my broken glass OUT of the assembly by threading it thru a limited space beneath the LCD. Later when trying to reseat the digitizer connector I gave up and removed the LCD anyhow. Not that much extra work but a LOT easier to install the digitizer and reseat the connector without having to navigate around the LCD and its cable. Removal of the tape holding the LCD was easy - there are two short lengths of rubber or foam along the bottom edge of the LCD that faces the outside world. Remove those(save them) and then _carefully_ peel up the tape; I saw some metallic looking residue underneath. Later when re-assembling everything, I put the tape back and then those two short lengths of foam.
  • Tout en tenant l'écran LCD d'une main, passez au côté gauche de l'iPad et répétez la procédure de l'étape précédente pour décoller le deuxième morceau de bande adhésive.
  • Insérez l'extrémité plate d'un spudger entre le cadre LCD et la bande adhésif, et faites-le glisser vers l'extérieur tout en soulevant doucement l'écran LCD.
  • Soulevez et retirez de l'iPad mini l'écran LCD.
  • Utilisez un outil d'ouverture en plastique pour tirer doucement le connecteur de la vitre tactile hors de sa prise sur la carte mère.
  • Veillez à faire levier de façon uniforme sur le connecteur et pas du tout sur la prise. La prise et le connecteur sont très fragiles et si vous endommagez un des deux, votre vitre tactile ne fonctionnera pas.
  • Retirez délicatement de la coque arrière la carte de la nappe de la vitre tactile.
Be careful not to dislodge any of the surface mount components next to the connectors. This is sometimes a reason for the digitiser not working.
Simon - Réponse
  • Soulevez et retirez le panneau frontal de l'iPad.
== After step 55 ==
Before installing your new digitizer (front panel), make sure to put the necessary bends on the new digitizer's ribbon cable. Look at the old panel that you've removed to see the bends that you'll need to make. Without doing this, once you are at the last step of laying down the digitizer, the cable may bunch-up in between the glass and the iPad's aluminum frame. Thus, it will not allow that corner to sit flush and glue down. If you didn't make the bends, you can use the tweezers at that point to situate the cable. It is just easier to do this beforehand. Do not make the bends as if you were folding paper. You run the risk of damaging the ribbon by doing so. You just want enough pressure to make the cable retain a bend. Again, look at and copy the cable from your old panel.
Good Luck!!!!
Mike - Réponse
If your panel is shattered, you may want to have some canned air to get rid of all those pesky little glass pieces that fly everywhere. I used a Giottos air blaster because that is all I had at my disposal.
Mike -
might be better to use a vacuum for safety reasons. you really dont want glass shards all over the place
If your case corners are damaged from being dropped, seal across the corners with wide packing tape, then grind them out carefully with a small motor tool. Use a corner piece from the broken screen (adhesive side upwards) as the template. Keep removing aluminium until screen piece above fits snug and flat. Remove all traces of metal filings before reassembly.
Jennifer Fordyce - Réponse
  • Utilisez une pincette pour décoller et retirer le petit morceau de ruban adhésif qui recouvre le connecteur de la nappe de la caméra frontale.
  • Le connecteur de la nappe de la caméra frontale est fixé avec des morceaux de ruban qui s'enroulent autour des côtés de la nappe et sont fixés à deux petites plaques métalliques.
  • Au cours des deux prochaines étapes, vous allez faire levier sur les deux plaques métalliques pour les soulever et les écarter du milieu de la nappe.
  • Utilisez un outil d'ouverture en plastique pour tirer délicatement la plaque métallique inférieure du connecteur de la nappe de la caméra frontale.
  • En prenant soin de ne pas casser la plaque ou la bande adhésive attachée à celle-ci, faites levier et écartez-la du connecteur de la nappe de la caméra frontale.
  • Retirez doucement la deuxième plaque métallique du connecteur de la nappe de la caméra frontale.
  • Encore une fois, soulevez soigneusement la plaque vers le haut et écartez-la du connecteur de la nappe de la caméra frontale.
  • Utilisez un outil d'ouverture en plastique pour extraire le connecteur de la nappe de la caméra frontale de sa prise sur la carte mère.
  • Utilisez une pincette pour décoller le haut du morceau rectangulaire de ruban adhésif recouvrant le coude de la nappe de la caméra frontale.
  • N'essayez pas d'enlever le ruban adhésif, car il est connecté sous la nappe.
  • Écartez le ruban adhésif de la nappe de la caméra frontale.
  • Reliez doucement la nappe de la caméra frontale vers le haut (à un angle d'environ 90 degrés), pour accéder au côté inférieur.
  • Tout en maintenant en haut la nappe de la caméra frontale, utilisez la pointe d'un spudger pour décoller le morceau de ruban adhésif sur le côté inférieur du coin de la nappe.
  • Le ruban adhésif est plié en deux pour attacher à la fois le dessous de la nappe de la caméra frontale et le côté supérieur de la nappe juste en dessous (nappe de la prise casque).
  • Utilisez la pointe d'un spudger pour tirer délicatement la caméra frontale vers l'avant et la décoller de l'adhésif la fixant à la coque arrière.
  • Retirez avec précaution la caméra frontale de l'iPad, en faisant passer sa nappe à travers la fente taillée près du bas de sa prise dans la coque arrière.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
2 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Andrew Optimus Goldberg
Membre depuis le 17/10/2009
383 986 Réputation
412 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
107 membres
6 501 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 1,162
