Aller au contenu principal
iPad Mini Wi-Fi Front Facing Camera Cable Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: étape 1, image 1 de 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement, Front Facing Camera Cable: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 2, image 1 de 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 2, image 2 de 2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 3, image 1 de 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 3, image 2 de 2
    • Gently pry the second metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 4, image 1 de 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 5, image 1 de 2 iPad Mini Wi-Fi Front Facing Camera Cable Replacement: étape 5, image 2 de 2
    • Gently fold the front-facing camera cable upwards (roughly at a 90-degree angle), exposing the bottom side of it.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
503 396 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
137 membres
17 457 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 45
