Aller au contenu principal
iPad Mini Wi-Fi Logic Board Assembly Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: étape 1, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement, Logic Board Assembly: étape 1, image 2 de 2
    • Use tweezers to peel up and remove the small piece of tape covering the front-facing camera cable connector.
  2. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 2, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 2, image 2 de 2
    • The front-facing camera cable connector is secured with pieces of tape that wrap up around the sides of the cable and are fastened to two small metal plates.
    • Use a plastic opening tool to gently pry the lower metal plate up from the front-facing camera cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the front-facing camera cable connector.
  3. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 3, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 3, image 2 de 2
    • Gently pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the front-facing camera cable connector.
  4. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 4, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 4, image 2 de 2
    • Use a plastic opening tool to pry the front-facing camera cable's connector up from its socket on the logic board.
  5. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 5, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 5, image 2 de 2
    • Gently fold the front-facing camera cable up and out of the way of the logic board.
  6. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 6, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 6, image 2 de 2
    • Use tweezers to peel up and remove the small piece of tape covering the headphone jack cable connector.
  7. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 7, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 7, image 2 de 2
    • Use a plastic opening tool to gently pry the lower metal plate up from the headphone jack cable connector.
    • Being careful not to break the plate or the tape attached to it, pry it up and fold it away from the headphone jack cable connector.
  8. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 8, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 8, image 2 de 2
    • Pry the second (upper) metal plate up from the front-facing camera cable connector.
    • Again, carefully pry the plate up and away from the headphone jack cable connector.
  9. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 9, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 9, image 2 de 2
    • Use a plastic opening tool to pry the headphone jack cable's connector up out of its socket on the logic board.
    • Gently bend the headphone jack cable back, away from the logic board.
  10. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 10, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 10, image 2 de 2
    • Use a plastic opening tool to pry the rear-facing camera cable up from its socket on the logic board.
  11. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 11, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 11, image 2 de 2
    • Use tweezers to peel up and remove the small piece of tape covering the button ribbon cable ZIF connector.
  12. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 12, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 12, image 2 de 2
    • Use the tip of a spudger to lift up the tab on the button ribbon cable ZIF connector.
  13. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 13, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 13, image 2 de 2
    • Use tweezers to pull the button ribbon cable straight out of its ZIF socket on the logic board.
  14. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 14, image 1 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 14, image 2 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 14, image 3 de 3
    • Gently peel back the wide piece of tape covering the top of the right speaker.
  15. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 15, image 1 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 15, image 2 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 15, image 3 de 3
    • Continue peeling the tape, and remove it from the iPad.
  16. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 16, image 1 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 16, image 2 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 16, image 3 de 3
    • Use the flat end of a spudger to disconnect the two bottom antenna cable connectors from their sockets on the logic board.
  17. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 17, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 17, image 2 de 2
    • Use the tip of a spudger to peel back the small piece of tape covering both antenna cables on the bottom right side of the iPad.
    • Leave the lower part of the tape stuck to the back of the rear case to aid in reassembly.
  18. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 18, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 18, image 2 de 2
    • With the tip of a spudger, peel up the larger piece of tape covering both antenna cables near the bottom of the rear case.
    • Do not try to remove this piece of tape; it is wrapped around the top antenna cable.
  19. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 19, image 1 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 19, image 2 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 19, image 3 de 3
    • Use the tip of a spudger to pry the small metal retaining clip off the left antenna cable, then de-route the cable from the clip.
  20. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 20, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 20, image 2 de 2
    • De-route the antenna cable from the corner of the iPad.
  21. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 21, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 21, image 2 de 2
    • Use the tip of a spudger to remove the small piece of tape securing the antenna cable in the bottom right corner of the iPad.
  22. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 22, image 1 de 1
    • Peel the cable back from the corner of the iPad.
  23. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 23, image 1 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 23, image 2 de 3 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 23, image 3 de 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  24. iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 24, image 1 de 2 iPad Mini Wi-Fi Logic Board Assembly Replacement: étape 24, image 2 de 2
    • Pull the antenna cable from the slot behind the Lightning connector.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
502 825 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
135 membres
16 817 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 45
