Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 11 Pro Front Camera Replacement Without Losing Face ID
Ce dont vous avez besoin
Vidéo d'introduction
    1. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the pentalobe screws: étape 1, image 2 de 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Demander à FixBot
      Ajouter un commentaire
    1. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Tape over any cracks: étape 2, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Tape over any cracks: étape 2, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Tape over any cracks: étape 2, image 3 de 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Demander à FixBot
    2. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Anti-Clamp instructions: étape 3, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Anti-Clamp instructions: étape 3, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Anti-Clamp instructions: étape 3, image 3 de 3
      Outil utilisé dans cette étape :
      Clampy - Anti-Clamp
      $24.95
      • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      Demander à FixBot
    3. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 4, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 4, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 4, image 3 de 3
      • Pull the blue handle forward to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      Demander à FixBot
    4. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 5, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 5, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 5, image 3 de 3
      • Heat an iOpener and thread it through the arms of the Anti-Clamp.
      • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
      • Fold the iOpener so it lays on the bottom edge of the iPhone.
      • Wait one minute to give the adhesive a chance to release and present an opening gap.
      • Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
      • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      Demander à FixBot
    5. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Heat the lower edge of the phone: étape 6, image 1 de 1
      • Heating the lower edge of the iPhone helps soften the adhesive securing the display, making it easier to open.
      • Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
      Demander à FixBot
    6. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 7, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 7, image 2 de 2
      • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the curved portion of the glass.
      Demander à FixBot
    7. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Lift the display slightly: étape 8, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Lift the display slightly: étape 8, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Lift the display slightly: étape 8, image 3 de 3
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
      • Insert an opening pick into the gap under the screen and the plastic bezelnot the screen itself.
      • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Demander à FixBot
    8. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Separate the screen adhesive: étape 9, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Separate the screen adhesive: étape 9, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Separate the screen adhesive: étape 9, image 3 de 3
      • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the display in place.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      Demander à FixBot
    9. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Screen information: étape 10, image 1 de 1
      • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
      Demander à FixBot
    10. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 11, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 11, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 11, image 3 de 3
      • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the display cables.
      Demander à FixBot
    11. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 12, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 12, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 12, image 3 de 3
      • The top edge of the display is secured with both glue and clips.
      • Gently pull the right edge of the display down slightly (in the direction of the Lightning port).
      • Insert your pick into the top-right corner of the phone.
      Demander à FixBot
    12. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 13, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 13, image 2 de 2
      • Continue pulling the display down (toward the Lightning port) as needed in order to make a gap large enough for the pick.
      • Slide the pick to the top left corner and cut any remaining adhesive securing the display.
      • Don't insert your pick more than 3 mm, as you may damage the front panel sensor array.
      Demander à FixBot
    13. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the suction cup: étape 14, image 1 de 1
      • Pull on the small nub on the suction cup to remove it from the front panel.
      Demander à FixBot
    14. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Open the iPhone: étape 15, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Open the iPhone: étape 15, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Open the iPhone: étape 15, image 3 de 3
      • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
      • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
      • Lean the display against something to keep it propped up while you're working on the phone.
      • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
      Demander à FixBot
    1. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Unscrew the battery connector cover: étape 16, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Unscrew the battery connector cover: étape 16, image 2 de 2
      Magnetic Project Mat
      $19.95
      • Remove two 1.3 mm long Y000 screws securing the battery cover bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
      Demander à FixBot
    2. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the battery connector cover: étape 17, image 1 de 1
      • Remove the bracket.
      Demander à FixBot
    3. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the battery: étape 18, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the battery: étape 18, image 2 de 2
      • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
      • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
      • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
      Demander à FixBot
    4. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Unscrew the logic board cover screws: étape 19, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Unscrew the logic board cover screws: étape 19, image 2 de 2
      • Use a Y000 driver to remove six 1.3 mm screws securing the logic board cover bracket.
      Demander à FixBot
    5. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the logic board cover bracket: étape 20, image 1 de 1
      Demander à FixBot
    6. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the Face ID hardware: étape 21, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the Face ID hardware: étape 21, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the Face ID hardware: étape 21, image 3 de 3
      • Use a spudger or a fingernail to disconnect the Face ID dot projector and sensor cables from their sockets on the logic board.
      Demander à FixBot
    7. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 22, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 22, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 22, image 3 de 3
      • Gently push the Face ID cable connectors away from the logic board to access the selfie cam connector underneath.
      • Disconnect the selfie cam by prying its connector straight up.
      Demander à FixBot
    8. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Test the replacement camera: étape 23, image 1 de 1
      • In order to ensure replacing the camera will resolve the issue, it is strongly recommended that the replacement camera be tested first.
      Demander à FixBot
    9. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Install the new front camera flex cable: étape 24, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Install the new front camera flex cable: étape 24, image 2 de 2
      • Connect the replacement camera by pressing the connector into its socket.
      Demander à FixBot
    10. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Reconnect the battery: étape 25, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Reconnect the battery: étape 25, image 2 de 2
      • Press the battery connector into its socket.
      Demander à FixBot
    11. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 26, image 1 de 1
      • Turn on the phone and open the camera.
      • Verify that the front and rear cameras work correctly.
      • If they do, we can conclude that replacing the damaged front camera will resolve the issue and can proceed with this repair.
      • If the new camera does not fix the problem then the rest of this procedure will be of no help. Stop here and reassemble your phone.
      Demander à FixBot
    12. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the battery: étape 27, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the battery: étape 27, image 2 de 2
      Demander à FixBot
    13. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the OLED display cable: étape 28, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the OLED display cable: étape 28, image 2 de 2
      • Use a spudger or a fingernail to disconnect the OLED panel cable connector.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Demander à FixBot
    14. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the front sensors + digitizer: étape 29, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the front sensors + digitizer: étape 29, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the front sensors + digitizer: étape 29, image 3 de 3
      • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
      • Use a spudger or a fingernail to disconnect the digitizer cable connector.
      • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      Demander à FixBot
    15. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the display assembly: étape 30, image 1 de 1
      Demander à FixBot
    16. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 31, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 31, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Disconnect the selfie cam: étape 31, image 3 de 3
      Demander à FixBot
    17. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 32, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 32, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 32, image 3 de 3
      • Grasp the front camera assembly with tweezers, being careful not to get fingerprints on the sensors.
      • Slide the front camera assembly slightly down and to the left to free it from the enclosure.
      Demander à FixBot
    18. iPhone 11 Pro Front Camera Replacement Without Losing Face ID, Remove the front-facing cameras: étape 33, image 1 de 1
      • Remove the front-facing cameras.
      Demander à FixBot
    19. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 34, image 1 de 1
      • In order to prevent damage the infrared camera and dot projector, apply Kapton tape to both parts.
      Demander à FixBot
    20. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 35, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 35, image 2 de 2
      • Turn the front camera module over and attach the assembly to a holder. Heat with a hot air gun at 100 °C to remove the tape.
      Demander à FixBot
    21. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 36, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 36, image 2 de 2
      • Grind the corner of the metal plate away with a Polishing & Grinding Pen or a Dremel multitool.
      • Pry up the metal plate with tweezers.
      Demander à FixBot
    22. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 37, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 37, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 37, image 3 de 3
      • Heat the front camera with a hot air gun at 100 °C for 30 seconds to loosen the adhesive bonding it to the frame.
      • Cover the front camera with a lint-free wipe and press gently.
      • Remove the damaged front camera.
      Demander à FixBot
    23. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 38, image 1 de 2 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 38, image 2 de 2
      • Apply adhesive to the edges of the frame surrounding the camera opening. Use it sparingly.
      • Install the new front camera, being careful to insert it squarely into the hole to avoid getting adhesive on the lens.
      Demander à FixBot
    24. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 39, image 1 de 1
      • Apply adhesive to the back of the camera and press the frame firmly down onto the camera.
      • Place the front camera in the holder with a retainer placed on top of the glued assembly to hold it in place as the adhesive dries.
      Demander à FixBot
    25. iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 40, image 1 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 40, image 2 de 3 iPhone 11 Pro Front Camera Replacement Without Losing Face ID: étape 40, image 3 de 3
      • After an hour, remove the front camera module. The front camera has been successfully replaced. Remove the Kapton tape from the IR camera and dot projector.
      • Install the front camera module and test. Turn on the phone. Both the front and rear cameras should work. Face ID should function too.
      Demander à FixBot
10 autres ont terminé cette réparation.
REWA
Membre depuis le 11/24/20
19 384 Réputation
55 tutoriels rédigés
7 commentaires de tutoriel
Really great and detailed! The pictures do an amazing job in aiding with understanding what to do! Thank you!
ShamelaJ - Réponse Partager
So can you replace FaceID parts like the dot projector and IR camera with aftermarket or third-party FaceID parts and use FaceID?
Austin G - Réponse Partager
Short answer: no. Replacing either will result in Face ID being disabled.
Jerry Wheeler - Réponse Partager
What’s the best software to replace Face ID to the logic board after replacing the camera?
Robert McKinnie - Réponse Partager
모든 과정을 완벽히 따라했고 디스플레이를 덮기 전까지 카메라가 작동하였습니다.
디스플레이를 덮은 후 카메라가 작동하지 않습니다.
저와 같은 증상이 있으신분?
김머시기 - Réponse Partager
Nombre de vues :
Dernières 24 heures : 14
7 derniers jours : 54
30 derniers jours : 234
Total : 24,261
