Introduction
Dot projector parts are extremely fragile. A fall or water damage may harm the dot projector parts, causing Face ID not to work. Since the dot projector IC is encrypted and replacement requires data encryption bonding for the new IC, repair technicians find it a challenge to repair the Face ID. The good news is that REWA LAB has developed a simple and efficient method to repair the Face ID. Let’s check it out!
Go to Settings > Face ID & Passcode > Set Up Face ID. When trying to set up Face ID, “Move iPhone a little lower/higher” pops up. Face ID cannot be normally set up. It can be judged that the dot projector of the Face ID has malfunctioned.
Remove the display and then detach the Face ID module. We can see a red mark, which indicates that the phone has water damage.
Connect the dot projector flex cable with the I2C Repair Programmer. The test shows that the dot projector flex cable has malfunctioned.
Press “Read” and read the data from the dot projector flex cable.
Connect a new I2C iPhone 11 Pro Max flex cable to the programmer. Press “Write” and write the data that has been read on the new flex cable.
Outil utilisé dans cette étape :Tweezers$4.99
Attach the dot projector module to the holder. To clean the tin on the dot projector module, smear rosin with the Soldering Iron at 365℃ and solder-wick.
Clean the module with PCB Cleaner afterward. Heat with Hot Air Gun at 240℃ and remove residual adhesive with tweezers.
Solder with Hot Air Gun at 320℃.
Connect the flex cable that has been soldered to the I2C programmer. Press “Test” and the screen shows “Pass,” which indicates that the flex cable is normal.
Attach the flex cable to the Holding Fixture and put the dot projector flex cable in position.
Please stay tuned for more content.
4 autres ont terminé cette réparation.
