Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
As we all know, iPhone new series have undergone considerable changes on both inside and outside. Especially on the motherboard. How will these changes affect the repair industry? Will it make third-party repair harder or easier? Find the answer by yourself now.
Vidéo d'introduction
  1. Compared with iPhone X series, iPhone 11 Pro’s motherboard is smaller with a much denser component array. It is also thicker. Remove the graphite thermal transfer material with tweezers first. Fit two screws into the screw holes reserved on the motherboard.
    • Compared with iPhone X series, iPhone 11 Pro’s motherboard is smaller with a much denser component array. It is also thicker.
    • Remove the graphite thermal transfer material with tweezers first.
    • Fit two screws into the screw holes reserved on the motherboard.
    • Place the motherboard on the heating platform to heat for 3 minutes.
    • Clamp the screws fitted into the screw holes with tweezers and pick up the upper layer with tweezers vertically.
    • Continue to pick up the lower layer.
  2. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  3. Place the lower layer on the heating platform to heat for 10 seconds. Apply some Paste Flux to the third space PCB evenly. Get the upper layer in position and heat for about 5 minutes.
    • Place the lower layer on the heating platform to heat for 10 seconds. Apply some Paste Flux to the third space PCB evenly. Get the upper layer in position and heat for about 5 minutes.
    • Then, press the SIM card reader with the tweezers and push the upper layer with another tweezers slightly. If the upper layer returns to the previous position automatically, then the soldering process is completed.
Phryne
Membre depuis le 17/11/2019
14 826 Réputation
80 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 48
Total : 939
