Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 11 Pro Rear Case Replacement
Ce dont vous avez besoin
Vidéo d'introduction
    1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
      • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
      • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
      Demander à FixBot
      Ajouter un commentaire
18 autres ont terminé cette réparation.
Arty
Membre depuis le 10/27/19
33 641 Réputation
110 tutoriels rédigés
3 commentaires de tutoriel
how much for housing iphone 11 pro ? Thank you
daddy - Réponse Partager
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas - Réponse Partager
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Réponse Partager
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 44
30 derniers jours : 241
Total : 23,874
