Aller au contenu principal
iPhone 12 Pentalobe Screws Replacement
Ce dont vous avez besoin
  1. iPhone 12 Pentalobe Screws Replacement, Remove the pentalobe screws: étape 1, image 1 de 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
8 autres ont terminé cette réparation.
Adam O'Camb
Membre depuis le 04/11/15
196 194 Réputation
416 tutoriels rédigés
4 commentaires
This is perfect, thank you! I wasn’t sure I’d be able to do this repair, but with this expert guidance I have succeeded. I’m ready for level 3.
Chris Phelan - Réponse
well done - would you like medal
Repairify Scotland -
someone just pointed out the fact it says to discharge the battery -
‘Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. ‘
you are removing the 2 pentalobes, not anything ‘internal’
Repairify Scotland - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 74
30 derniers jours : 317
Total : 8,219
