Aller au contenu principal
Introduction
The Taptic Engine produces your iPhone's vibration and haptic feedback functions. Use this guide to remove and replace the Taptic Engine in an iPhone 14 Pro Max.
This guide was created using the A2894 (international) model. If you're fixing a different iPhone 14 Pro Max model, there may be some visual discrepancies, but the procedure should be the same.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
  1. iPhone 14 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: étape 1, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Remove the pentalobe screws: étape 1, image 2 de 2
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
  2. iPhone 14 Pro Max Taptic Engine Replacement, Heat the bottom edge of the iPhone: étape 2, image 1 de 1
    • Heating the lower edge of the iPhone helps soften the adhesive securing the screen, making it easier to open.
    • Apply a heated iOpener to the bottom edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
  3. iPhone 14 Pro Max Taptic Engine Replacement, Insert an opening pick: étape 3, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Insert an opening pick: étape 3, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Insert an opening pick: étape 3, image 3 de 3
    • Apply a suction handle to the bottom edge of the screen, while avoiding the very edge of the glass.
    • Pull up on the suction handle with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick into the gap.
    • The adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your opening pick.
  4. iPhone 14 Pro Max Taptic Engine Replacement, Heat and separate the screen adhesive: étape 4, image 1 de 1
    • Apply a heated iOpener to the left edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  5. iPhone 14 Pro Max Taptic Engine Replacement, Slice the left edge adhesive: étape 5, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the left edge adhesive: étape 5, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the left edge adhesive: étape 5, image 3 de 3
    • Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the screen in place.
    • Don't insert the pick more than 3 mm inside your phone, or you may damage the display cables.
  6. iPhone 14 Pro Max Taptic Engine Replacement, Heat and separate the screen adhesive: étape 6, image 1 de 1
    • Apply a heated iOpener to the right edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  7. iPhone 14 Pro Max Taptic Engine Replacement, Slice the right edge adhesive: étape 7, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the right edge adhesive: étape 7, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the right edge adhesive: étape 7, image 3 de 3
    • Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
    • Don't insert the opening pick more than 3 mm into the iPhone, or you may cause damage to internal components.
  8. iPhone 14 Pro Max Taptic Engine Replacement, Heat the top edge of the iPhone: étape 8, image 1 de 1
    • Apply a heated iOpener to the top edge of the screen to loosen the adhesive underneath. Apply the iOpener for at least 2 minutes.
  9. iPhone 14 Pro Max Taptic Engine Replacement, Slice the top edge adhesive: étape 9, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the top edge adhesive: étape 9, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Slice the top edge adhesive: étape 9, image 3 de 3
    • Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and half way across the top edge stopping right before the earpiece speaker cut-out.
    • Don't insert the pick more than 2 mm or you may damage the front panel sensor array.
  10. iPhone 14 Pro Max Taptic Engine Replacement: étape 10, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement: étape 10, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement: étape 10, image 3 de 3
    • Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and half way across the top edge stopping right before the earpiece speaker cut-out.
    • Again, don't insert the pick more than 3 mm or you may damage the front panel sensor array.
    • Don't try to fully separate the screen yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 14 Pro Max Taptic Engine Replacement, Open the iPhone: étape 11, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Open the iPhone: étape 11, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Open the iPhone: étape 11, image 3 de 3
    • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
    • Lean the screen against something to keep it propped up while you're working on the phone.
    • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
    • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
    • Use a Y000 screwdriver to remove the eight screws securing the battery connector cover:
    • Six 1.3 mm-long screws
    • One 1.6 mm-long screw
    • One 1.9 mm-long screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
  12. iPhone 14 Pro Max Taptic Engine Replacement, Remove the battery connector cover: étape 13, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Remove the battery connector cover: étape 13, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Remove the battery connector cover: étape 13, image 3 de 3
    • Grasp the connector cover with a pair of tweezers and slide it downwards to clear the flex cables.
    • Remove the connector cover.
  13. iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the battery: étape 14, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the battery: étape 14, image 2 de 2
    • Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  14. iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the display cables: étape 15, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the display cables: étape 15, image 2 de 2
    • Use the pointed end of a spudger to disconnect the first display cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPhone 14 Pro Max Taptic Engine Replacement: étape 16, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement: étape 16, image 2 de 2
    • Use the pointed end of a spudger to disconnect the second display cable by prying the connector straight up from its socket.
  16. iPhone 14 Pro Max Taptic Engine Replacement, Remove the screen: étape 17, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Remove the screen: étape 17, image 2 de 2
    • Remove the screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, pause here if you wish to replace the screen adhesives.
  17. iPhone 14 Pro Max Taptic Engine Replacement, Unfasten the loudspeaker screws: étape 18, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Unfasten the loudspeaker screws: étape 18, image 2 de 2
    • Use a Phillips driver to remove the four 1.5 mm-long screws securing the loudspeaker:
    • Three smaller-headed screws
    • One larger-headed screw
  18. iPhone 14 Pro Max Taptic Engine Replacement, Loosen the loudspeaker: étape 19, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Loosen the loudspeaker: étape 19, image 2 de 2
    • Use the flat end of a spudger to pry up and loosen the loudspeaker from the bottom right corner of the phone.
  19. iPhone 14 Pro Max Taptic Engine Replacement, Remove the loudspeaker: étape 20, image 1 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Remove the loudspeaker: étape 20, image 2 de 3 iPhone 14 Pro Max Taptic Engine Replacement, Remove the loudspeaker: étape 20, image 3 de 3
    • Use a pair of tweezers to grab the loudspeaker.
    • Tilt the loudspeaker to separate it from the adhesive-backed strip that leads to the Taptic Engine.
    • Remove the loudspeaker.
    • When reinstalling the loudspeaker, place it in its recess battery-side first to align it with the adhesive-backed strip.
  20. iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: étape 21, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Disconnect the Taptic Engine: étape 21, image 2 de 2
    • Use a spudger to disconnect the Taptic Engine by prying the connector straight up from its socket.
    • Use a Phillips screwdriver to remove two screws securing the Taptic Engine:
    • One 1.8 mm-long screw
    • One 2.3 mm-long screw
    • Use a standoff screwdriver to remove the 2.9 mm-long standoff screw securing the Taptic Engine.
    • Standoff screws are best removed using a dedicated standoff driver or driver bit. In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  21. iPhone 14 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: étape 23, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Remove the Taptic Engine: étape 23, image 2 de 2
    • Use a pair of tweezers or your fingers to remove the Taptic Engine.
  22. iPhone 14 Pro Max Taptic Engine Replacement, Transfer the adhesive-backed strip: étape 24, image 1 de 2 iPhone 14 Pro Max Taptic Engine Replacement, Transfer the adhesive-backed strip: étape 24, image 2 de 2
    • If your replacement part didn’t come with the plastic strip along the top of the Taptic Engine, you'll need to transfer it to your replacement part.
    • Use your fingers or a pair of tweezers to gently peel the adhesive-backed strip off of the Taptic Engine.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
145 420 Réputation
595 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
147 membres
16 036 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 30
30 derniers jours : 183
Total : 643
