Introduction
Use this guide to replace the rear cameras in your iPhone 14.
This guide was created using the A2882 (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
Note: On iOS 18 and newer, you can calibrate new, genuine camera modules using Apple's Repair Assistant.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
Ce dont vous avez besoin
Power off your iPhone before beginning disassembly.
Use a P2 pentalobe screwdriver to remove the two 6.8 mm‑long screws on either side of the charging port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the rear glass is slightly too hot to touch.
Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the case.
Insert an opening pick into the gap.
Heat the left edge of the iPhone until the rear glass is slightly too hot to touch.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
Heat the right edge of the iPhone (the edge with the volume buttons) until the rear glass is slightly too hot to touch.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Heat the top edge of the iPhone until the rear glass is slightly too hot to touch.
Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
Remove your suction handle from the rear glass.
Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
Lean the rear glass against something to keep it propped up while you're working on the phone.
If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
Outil utilisé dans cette étape :Magnetic Project Mat$19.95
Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
Outil utilisé dans cette étape :Tweezers$4.99
Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
Use a pair of tweezers to remove the charging coil connector cover.
Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
Use a spudger to disconnect the two rear facing camera cables by prying the connectors straight up from their sockets.
Use a Phillips screwdriver to remove the three 2.1 mm-long screws securing the rear camera assembly.
Insert the pointed end of a spudger underneath the top edge of the rear-facing camera assembly.
Pry up with the spudger to loosen the rear-facing camera assembly.
Use a pair of tweezers or your fingers to remove the rear-facing camera assembly.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
8 autres ont terminé cette réparation.
4 commentaires de tutoriel
Be Careful!! In certain models you also have to unplug the cable that goes over the camera cables, and lift it slightly out of the way. (this cable plugs in just below where the wireless coil plugs in) failure to do so will rip this cable.
I need your help.
iPhone 14 backcamera not working.
Opened the iPhone, disconnected battery and camera, reconnected everything and closed the phone.
Camera is working for a few hours and then it went black again.
iPhone didn’t drop, no water or anything. Just using it. Took a bunch of photos and next photo didn’t work anymore.
Any ideas? I already cleaned the connectors with alcohol. Nothing changed. Closed the phone and camera is working only for a few hours.
A new camera is so %#*@ expensive and even I don’t know if it is really a hardware problem of the cam.
Hey Pättes,
Do the other cameras work when you use the camera app? If you can, try a third-party camera app to see if it can display anything. If nothing displays, there's a high chance it's a hardware issue.
When you start the camera app and it shows only black, does the camera area around the back cover get very hot after a minute—almost too hot to the touch? If so, it's likely a hardware malfunction.
Die Anleitung ist sehr gut. Beim Zusammenbau ist mir leider das Kabel zur Ladespule auf der Rückseite gerissen. Ich habe dann eine neue Ladespule (iPhone 14 Wireless Charging Antenna) bestellt und mithilfe der iFixit-Anleitung (https://de.ifixit.com/Anleitung/iPhone+1...) den Austausch durchgeführt. Das hat super funktioniert und ist vielleicht auch ein Tipp für diejenigen, denen es auch passiert.
