Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 15 Rear Cameras Replacement
Ce dont vous avez besoin
  1. iPhone 15 Rear Cameras Replacement, Prepare your phone for disassembly: étape 1, image 1 de 2 iPhone 15 Rear Cameras Replacement, Prepare your phone for disassembly: étape 1, image 2 de 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Rear Cameras Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 15 Rear Cameras Replacement, Tape over any cracks: étape 2, image 2 de 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Rear Cameras Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 15 Rear Cameras Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 15 Rear Cameras Replacement, Mark your opening picks: étape 3, image 3 de 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  4. iPhone 15 Rear Cameras Replacement, Remove the pentalobe screws: étape 4, image 1 de 2 iPhone 15 Rear Cameras Replacement, Remove the pentalobe screws: étape 4, image 2 de 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  5. iPhone 15 Rear Cameras Replacement, Heat the bottom edge: étape 5, image 1 de 1
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 15 Rear Cameras Replacement, Insert an opening pick: étape 6, image 1 de 3 iPhone 15 Rear Cameras Replacement, Insert an opening pick: étape 6, image 2 de 3 iPhone 15 Rear Cameras Replacement, Insert an opening pick: étape 6, image 3 de 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 15 Rear Cameras Replacement, Back glass information: étape 7, image 1 de 1
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
  8. iPhone 15 Rear Cameras Replacement, Separate the bottom edge adhesive: étape 8, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the bottom edge adhesive: étape 8, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the bottom edge adhesive: étape 8, image 3 de 3
    • Don't insert your opening pick deeper than 5 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  9. iPhone 15 Rear Cameras Replacement, Heat the right edge: étape 9, image 1 de 1
    • Heat the right edge of the back glass until it's hot to the touch.
  10. iPhone 15 Rear Cameras Replacement, Separate the bottom right corner adhesive: étape 10, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the bottom right corner adhesive: étape 10, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the bottom right corner adhesive: étape 10, image 3 de 3
    • Don't insert your pick deeper than 7 mm along the right edge.
    • Rotate your pick around the bottom right corner and slide it to the volume down button or until you feel a hard stop at a large clip securing the back glass.
    • Don't slice past the volume buttons to avoid damaging the wireless charging cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 15 Rear Cameras Replacement, Heat the left edge: étape 11, image 1 de 1
    • Heat the left edge of the back glass until it's hot to the touch.
  12. iPhone 15 Rear Cameras Replacement, Separate the left edge adhesive: étape 12, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the left edge adhesive: étape 12, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the left edge adhesive: étape 12, image 3 de 3
    • Along the left edge, don't insert your pick deeper than 5 mm.
    • Insert a second opening pick at the bottom edge.
    • Rotate the second pick around the bottom left corner.
    • Slide this pick up to the top left corner to separate the adhesive.
  13. iPhone 15 Rear Cameras Replacement, Heat the top edge: étape 13, image 1 de 1
    • Heat the top edge of the back glass until it's hot to the touch.
  14. iPhone 15 Rear Cameras Replacement, Separate the top edge adhesive: étape 14, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the top edge adhesive: étape 14, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the top edge adhesive: étape 14, image 3 de 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Rotate your second opening pick around the top left corner and slide it to the top right corner to separate the adhesive.
    • You might hear and feel clicks as the top two clips release.
    • Leave this pick in place to prevent the adhesive from resealing.
  15. iPhone 15 Rear Cameras Replacement, Heat the top right corner: étape 15, image 1 de 1
    • Heat the top right corner of the back glass until it's hot to the touch.
  16. iPhone 15 Rear Cameras Replacement, Separate the top right corner adhesive: étape 16, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the top right corner adhesive: étape 16, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the top right corner adhesive: étape 16, image 3 de 3
    • Don't insert your pick deeper than 4 mm along the right edge.
    • Rotate the second opening pick around the top right corner and slide it to the volume up button to separate the adhesive.
  17. iPhone 15 Rear Cameras Replacement, Open the back glass: étape 17, image 1 de 3 iPhone 15 Rear Cameras Replacement, Open the back glass: étape 17, image 2 de 3 iPhone 15 Rear Cameras Replacement, Open the back glass: étape 17, image 3 de 3
    • Gently lift and swing open the back glass to the right of the phone.
    • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the back glass against a raised surface so it doesn't strain the cable.
  18. iPhone 15 Rear Cameras Replacement, Unfasten the lower connector cover: étape 18, image 1 de 1
    Outil utilisé dans cette étape :
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the two 1.3 mm-long screws securing the lower connector cover.
  19. iPhone 15 Rear Cameras Replacement, Remove the lower connector cover: étape 19, image 1 de 3 iPhone 15 Rear Cameras Replacement, Remove the lower connector cover: étape 19, image 2 de 3 iPhone 15 Rear Cameras Replacement, Remove the lower connector cover: étape 19, image 3 de 3
    • Use tweezers to slide the cover toward the top of the phone to unlatch it from the logic board.
    • Remove the cover.
  20. iPhone 15 Rear Cameras Replacement, Disconnect the battery: étape 20, image 1 de 3 iPhone 15 Rear Cameras Replacement, Disconnect the battery: étape 20, image 2 de 3 iPhone 15 Rear Cameras Replacement, Disconnect the battery: étape 20, image 3 de 3
    • Hold the back glass upright with one hand and rotate it just enough to reveal the battery press connector just below the volume buttons.
    • A plus and minus sign is printed on the head of this connector.
    • Use the tip of an opening pick to pry up and disconnect the battery press connector from the logic board.
  21. iPhone 15 Rear Cameras Replacement, Unfasten the middle connector cover: étape 21, image 1 de 2 iPhone 15 Rear Cameras Replacement, Unfasten the middle connector cover: étape 21, image 2 de 2
    • Use your tri-point Y000 driver to remove the 0.9 mm-long screw securing the middle connector cover.
  22. iPhone 15 Rear Cameras Replacement, Remove the cover: étape 22, image 1 de 3 iPhone 15 Rear Cameras Replacement, Remove the cover: étape 22, image 2 de 3 iPhone 15 Rear Cameras Replacement, Remove the cover: étape 22, image 3 de 3
    • Use the flat end of a spudger or your finger to push the cover toward the bottom of the phone and unclip its top edge.
    • Remove the cover.
  23. iPhone 15 Rear Cameras Replacement, Disconnect the wireless charging coil: étape 23, image 1 de 2 iPhone 15 Rear Cameras Replacement, Disconnect the wireless charging coil: étape 23, image 2 de 2
    • Use an opening pick to pry up and disconnect the wireless charging coil and NFC connector.
  24. iPhone 15 Rear Cameras Replacement, Remove the back glass: étape 24, image 1 de 1
    • Remove the back glass.
  25. iPhone 15 Rear Cameras Replacement, Disconnect the rear cameras and antenna: étape 25, image 1 de 3 iPhone 15 Rear Cameras Replacement, Disconnect the rear cameras and antenna: étape 25, image 2 de 3 iPhone 15 Rear Cameras Replacement, Disconnect the rear cameras and antenna: étape 25, image 3 de 3
    • Use the tip of an opening pick to pry up and disconnect the two rear camera press connectors and the antenna press connector located to the top right of the battery.
  26. iPhone 15 Rear Cameras Replacement, Unfasten the rear cameras: étape 26, image 1 de 1
    • Use a Phillips #00 driver to remove the three 2.3 mm‑long screws securing the rear cameras.
  27. iPhone 15 Rear Cameras Replacement, Free the camera cables: étape 27, image 1 de 3 iPhone 15 Rear Cameras Replacement, Free the camera cables: étape 27, image 2 de 3 iPhone 15 Rear Cameras Replacement, Free the camera cables: étape 27, image 3 de 3
    • The rear camera cables route underneath the antenna cable, making rear camera removal tricky. Follow the next two steps to free the camera cables.
    • Use your fingers to grab the upper camera and antenna press connectors and lift their cables out from their channels along the edge of the battery.
    • This leaves just the middle of the three press connectors in place.
  28. iPhone 15 Rear Cameras Replacement, Separate the antenna cable adhesive: étape 28, image 1 de 3 iPhone 15 Rear Cameras Replacement, Separate the antenna cable adhesive: étape 28, image 2 de 3 iPhone 15 Rear Cameras Replacement, Separate the antenna cable adhesive: étape 28, image 3 de 3
    • The cable for the middle press connector is adhered to an adjacent cable along the top edge of the battery. In this step, you'll separate this adhesive.
    • Hold the two cables you just freed out of the way of the middle press connector cable.
    • Insert the tip of an opening pick between the middle press connector cable and its adjacent cable to separate the adhesive.
  29. iPhone 15 Rear Cameras Replacement, Pry up the rear cameras: étape 29, image 1 de 2 iPhone 15 Rear Cameras Replacement, Pry up the rear cameras: étape 29, image 2 de 2
    • Use the flat end of your spudger to pry up the top edge of the rear cameras until you can grab them with your fingers.
  30. iPhone 15 Rear Cameras Replacement, Remove the rear cameras: étape 30, image 1 de 3 iPhone 15 Rear Cameras Replacement, Remove the rear cameras: étape 30, image 2 de 3 iPhone 15 Rear Cameras Replacement, Remove the rear cameras: étape 30, image 3 de 3
    • Pull the rear cameras toward the top of the phone and let their cables slide underneath the antenna cable.
    • Remove the rear cameras.
  31. iPhone 15 Rear Cameras Replacement, End of disassembly: étape 31, image 1 de 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    • When reconnecting press connectors, align the connector carefully over its socket and press down with your fingertip or spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  32. iPhone 15 Rear Cameras Replacement, Place the rear cameras: étape 32, image 1 de 3 iPhone 15 Rear Cameras Replacement, Place the rear cameras: étape 32, image 2 de 3 iPhone 15 Rear Cameras Replacement, Place the rear cameras: étape 32, image 3 de 3
    • Place the rear cameras into their slot, making sure the camera cables route underneath the antenna cable.
    • Use this picture for reference to order the cables correctly.
  33. iPhone 15 Rear Cameras Replacement: étape 33, image 1 de 2 iPhone 15 Rear Cameras Replacement: étape 33, image 2 de 2
    • Slide the rear camera cable back into its slot along the battery.
  34. iPhone 15 Rear Cameras Replacement, Install the rear cameras screws: étape 34, image 1 de 1
    • Use a Phillips #00 driver to install the three 2.3 mm‑long screws securing the rear cameras.
  35. iPhone 15 Rear Cameras Replacement, Connect the rear cameras and antenna: étape 35, image 1 de 2 iPhone 15 Rear Cameras Replacement, Connect the rear cameras and antenna: étape 35, image 2 de 2
    • Use a spudger or your fingers to connect the two rear camera press connectors and the antenna press connector.
  36. iPhone 15 Rear Cameras Replacement, Remove the back glass adhesive: étape 36, image 1 de 2 iPhone 15 Rear Cameras Replacement, Remove the back glass adhesive: étape 36, image 2 de 2
    • Be careful not to damage any of the spring contacts as you clean the frame.
    • This is a good point to test your repair before sealing up your phone. Connect the battery and back glass, power on your phone, and make sure it works as expected. Power it back down, disconnect the battery and back glass, and continue reassembly.
    • The adhesive remaining on your phone is difficult to remove and leaves residue. If you have trouble removing the adhesive, apply some heat using a hair dryer or heat gun.
    • Use the pointed end of a spudger to press and roll the adhesive until you can grip it with a pair of tweezers.
    • Use the tweezers to pull the adhesive off of the phone.
  37. iPhone 15 Rear Cameras Replacement: étape 37, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 37, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 37, image 3 de 3
    • Any leftover residue will compromise your iPhone's seal. Be sure to clean the frame thoroughly.
    • Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
  38. iPhone 15 Rear Cameras Replacement, Orient the adhesive: étape 38, image 1 de 3 iPhone 15 Rear Cameras Replacement, Orient the adhesive: étape 38, image 2 de 3 iPhone 15 Rear Cameras Replacement, Orient the adhesive: étape 38, image 3 de 3
    • Lay the adhesive next to the phone and use features like cutouts for spring contacts and the rear camera to make sure the adhesive is oriented correctly.
    • Your adhesive may look slightly different.
  39. iPhone 15 Rear Cameras Replacement, Apply the adhesive: étape 39, image 1 de 3 iPhone 15 Rear Cameras Replacement, Apply the adhesive: étape 39, image 2 de 3 iPhone 15 Rear Cameras Replacement, Apply the adhesive: étape 39, image 3 de 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  40. iPhone 15 Rear Cameras Replacement: étape 40, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 40, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 40, image 3 de 3
    • When the adhesive is aligned, use the flat end of a spudger or your finger to press it down firmly along the bottom edge.
  41. iPhone 15 Rear Cameras Replacement: étape 41, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 41, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 41, image 3 de 3
    • Continue peeling the back liner off of the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  42. iPhone 15 Rear Cameras Replacement, Press the adhesive into place: étape 42, image 1 de 3 iPhone 15 Rear Cameras Replacement, Press the adhesive into place: étape 42, image 2 de 3 iPhone 15 Rear Cameras Replacement, Press the adhesive into place: étape 42, image 3 de 3
    • Make sure the liner is aligned properly by checking that all spring contacts and the rear camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
    • Be careful not to touch the spring contacts sticking through the pink liner.
  43. iPhone 15 Rear Cameras Replacement, Remove the top liner: étape 43, image 1 de 3 iPhone 15 Rear Cameras Replacement, Remove the top liner: étape 43, image 2 de 3 iPhone 15 Rear Cameras Replacement, Remove the top liner: étape 43, image 3 de 3
    • Remove the top adhesive liner.
    • Depending on your adhesive, your liner might be split into multiple parts or be a single piece.
  44. iPhone 15 Rear Cameras Replacement, Prop up the back glass: étape 44, image 1 de 3 iPhone 15 Rear Cameras Replacement, Prop up the back glass: étape 44, image 2 de 3 iPhone 15 Rear Cameras Replacement, Prop up the back glass: étape 44, image 3 de 3
    • Prop up the back glass along the right edge of the iPhone, using a box or similar sturdy object to support the screen.
    • Use the flat end of a spudger or your finger to connect the wireless charging coil press connector, then the battery press connector.
  45. iPhone 15 Rear Cameras Replacement, Place the middle connector cover: étape 45, image 1 de 2 iPhone 15 Rear Cameras Replacement, Place the middle connector cover: étape 45, image 2 de 2
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
  46. iPhone 15 Rear Cameras Replacement: étape 46, image 1 de 2 iPhone 15 Rear Cameras Replacement: étape 46, image 2 de 2
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
  47. iPhone 15 Rear Cameras Replacement, Place the lower connector cover: étape 47, image 1 de 3 iPhone 15 Rear Cameras Replacement, Place the lower connector cover: étape 47, image 2 de 3 iPhone 15 Rear Cameras Replacement, Place the lower connector cover: étape 47, image 3 de 3
    • Use tweezers to hook the top of the lower connector cover into its slot on the logic board.
    • Lay the lower connector cover over the press connectors.
  48. iPhone 15 Rear Cameras Replacement, Install the cover screws: étape 48, image 1 de 2 iPhone 15 Rear Cameras Replacement, Install the cover screws: étape 48, image 2 de 2
    • Use a tri-point Y000 screwdriver to install the 0.9 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
  49. iPhone 15 Rear Cameras Replacement, Remove the final adhesive liners: étape 49, image 1 de 2 iPhone 15 Rear Cameras Replacement, Remove the final adhesive liners: étape 49, image 2 de 2
    • Use tweezers or your fingers to separate the pull tabs at the bottom of the frame, near the charging port.
  50. iPhone 15 Rear Cameras Replacement: étape 50, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 50, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 50, image 3 de 3
    • Remove the narrow liner covering the adhesive along the left and top edges of the frame.
  51. iPhone 15 Rear Cameras Replacement: étape 51, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 51, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 51, image 3 de 3
    • Hold the back glass over the phone without letting it touch the adhesive, so you can access the remaining liners along the right edge of the phone.
    • Use a pair of tweezers or your fingers to remove the remaing liners along the right edge of the phone.
  52. iPhone 15 Rear Cameras Replacement, Install the back glass: étape 52, image 1 de 3 iPhone 15 Rear Cameras Replacement, Install the back glass: étape 52, image 2 de 3 iPhone 15 Rear Cameras Replacement, Install the back glass: étape 52, image 3 de 3
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all the clips.
  53. iPhone 15 Rear Cameras Replacement, Heat the back glass: étape 53, image 1 de 2 iPhone 15 Rear Cameras Replacement, Heat the back glass: étape 53, image 2 de 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
  54. iPhone 15 Rear Cameras Replacement, Press the back glass: étape 54, image 1 de 3 iPhone 15 Rear Cameras Replacement, Press the back glass: étape 54, image 2 de 3 iPhone 15 Rear Cameras Replacement, Press the back glass: étape 54, image 3 de 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  55. iPhone 15 Rear Cameras Replacement: étape 55, image 1 de 2 iPhone 15 Rear Cameras Replacement: étape 55, image 2 de 2
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  56. iPhone 15 Rear Cameras Replacement: étape 56, image 1 de 3 iPhone 15 Rear Cameras Replacement: étape 56, image 2 de 3 iPhone 15 Rear Cameras Replacement: étape 56, image 3 de 3
    • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
    • Stack them to a consistent height taller than the camera bump.
  57. iPhone 15 Rear Cameras Replacement: étape 57, image 1 de 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
  58. iPhone 15 Rear Cameras Replacement, Install the pentalobe screws: étape 58, image 1 de 2 iPhone 15 Rear Cameras Replacement, Install the pentalobe screws: étape 58, image 2 de 2
    • Use a P2 pentalobe driver to install the two 7.7 mm‑long screws on either side of the charging port.
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
2 autres ont terminé cette réparation.
Clay Eickemeyer
Membre depuis le 09/19/22
98 536 Réputation
471 tutoriels rédigés
Équipe
Guide Team Membre de l'équipe Guide Team
Staff
10 membres
16 273 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 25
7 derniers jours : 195
30 derniers jours : 796
Total : 11,188
