Aller au contenu principal
Pour réparer ensemble - Je crée un compte
iPhone 16 Pro Screen Replacement
Ce dont vous avez besoin
    1. iPhone 16 Pro Screen Replacement, Prepare the phone for disassembly: étape 1, image 1 de 2 iPhone 16 Pro Screen Replacement, Prepare the phone for disassembly: étape 1, image 2 de 2
      • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from the phone.
      • Hold the power and either volume buttons and slide to power off the phone.
      Demander à FixBot
      Ajouter un commentaire
    2. iPhone 16 Pro Screen Replacement, Tape over any cracks: étape 2, image 1 de 2 iPhone 16 Pro Screen Replacement, Tape over any cracks: étape 2, image 2 de 2
      • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Demander à FixBot
    3. iPhone 16 Pro Screen Replacement, Mark your opening picks: étape 3, image 1 de 3 iPhone 16 Pro Screen Replacement, Mark your opening picks: étape 3, image 2 de 3 iPhone 16 Pro Screen Replacement, Mark your opening picks: étape 3, image 3 de 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Demander à FixBot
    4. iPhone 16 Pro Screen Replacement, Remove the pentalobe screws: étape 4, image 1 de 2 iPhone 16 Pro Screen Replacement, Remove the pentalobe screws: étape 4, image 2 de 2
      • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Create a gap with a suction handle: étape 5, image 1 de 1
      Outil utilisé dans cette étape :
      iOpener
      $14.95
      • The next two steps show how to create an initial gap using a suction handle.
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
      Demander à FixBot
    2. iPhone 16 Pro Screen Replacement: étape 6, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 6, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 6, image 3 de 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • If you can't create a gap, apply more heat to the edge and try again.
      • Insert the tip of an opening pick into the gap.
      Demander à FixBot
    3. iPhone 16 Pro Screen Replacement, Screen information: étape 7, image 1 de 1
      • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
      • Multiple spring contacts around the perimeter of the iPhone
      Demander à FixBot
    4. iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: étape 8, image 1 de 3 iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: étape 8, image 2 de 3 iPhone 16 Pro Screen Replacement, Slice the bottom edge adhesive: étape 8, image 3 de 3
      • Slide the opening pick along the bottom edge to release the adhesive.
      • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
      • If the adhesive feels difficult to slice, reheat the edge for a minute.
      • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
      Demander à FixBot
    5. iPhone 16 Pro Screen Replacement, Heat the left edge: étape 9, image 1 de 1
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
      Demander à FixBot
    6. iPhone 16 Pro Screen Replacement, Separate the left adhesive: étape 10, image 1 de 2 iPhone 16 Pro Screen Replacement, Separate the left adhesive: étape 10, image 2 de 2
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
      • Insert a second opening pick in the bottom-left corner, close to the existing pick.
      • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
      • You'll hear and feel the metal clips release as you pass them.
      • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
      Demander à FixBot
    7. iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: étape 11, image 1 de 3 iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: étape 11, image 2 de 3 iPhone 16 Pro Screen Replacement, Separate the remaining adhesives: étape 11, image 3 de 3
      • Repeat the heating and slicing procedure along the remaining screen edges.
      Demander à FixBot
    8. iPhone 16 Pro Screen Replacement, Swing open the screen: étape 12, image 1 de 3 iPhone 16 Pro Screen Replacement, Swing open the screen: étape 12, image 2 de 3 iPhone 16 Pro Screen Replacement, Swing open the screen: étape 12, image 3 de 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
      • Carefully lift the screen upwards until the clips along the long edges clear the frame.
      • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
      Demander à FixBot
    9. iPhone 16 Pro Screen Replacement, Remove the connector covers: étape 13, image 1 de 1
      • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
      Demander à FixBot
    10. iPhone 16 Pro Screen Replacement: étape 14, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 14, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 14, image 3 de 3
      • Use tweezers to grasp the front sensor connector cover near the screw hole.
      • Lift and remove the cover.
      Demander à FixBot
    11. iPhone 16 Pro Screen Replacement: étape 15, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 15, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 15, image 3 de 3
      • Repeat this process for the other cover.
      Demander à FixBot
    12. iPhone 16 Pro Screen Replacement, Disconnect the screen: étape 16, image 1 de 2 iPhone 16 Pro Screen Replacement, Disconnect the screen: étape 16, image 2 de 2
      • Use the tip of a spudger to pry up and disconnect the display press connector.
      Demander à FixBot
    13. iPhone 16 Pro Screen Replacement: étape 17, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 17, image 2 de 2
      • Repeat this process for the front sensor press connector.
      Demander à FixBot
    14. iPhone 16 Pro Screen Replacement, Remove the screen: étape 18, image 1 de 1
      • Remove the screen.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Disassembly complete: étape 19, image 1 de 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone. Some of the reassembly photos show the Pro Max model, but the procedure is correct for the Pro.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Ambient light sensor information: étape 20, image 1 de 1
      • The ambient light sensor is located behind the screen, next to the cut‑out for the Face ID sensors.
      • Check if the replacement screen comes with one installed. If it does, click here to skip the next twelve steps.
      Demander à FixBot
    2. iPhone 16 Pro Screen Replacement, Remove the ambient light sensor bracket: étape 21, image 1 de 2 iPhone 16 Pro Screen Replacement, Remove the ambient light sensor bracket: étape 21, image 2 de 2
      • Use a Phillips screwdriver to remove the 1 mm‑long screw securing the bracket on the ambient light sensor.
      Demander à FixBot
    3. iPhone 16 Pro Screen Replacement: étape 22, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 22, image 2 de 2
      • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
      Demander à FixBot
    4. iPhone 16 Pro Screen Replacement, Heat the ambient light sensor cable: étape 23, image 1 de 1
      • Use a hair dryer, heat gun, or iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
      Demander à FixBot
    5. iPhone 16 Pro Screen Replacement, Peel up the ambient light sensor cable: étape 24, image 1 de 3 iPhone 16 Pro Screen Replacement, Peel up the ambient light sensor cable: étape 24, image 2 de 3 iPhone 16 Pro Screen Replacement, Peel up the ambient light sensor cable: étape 24, image 3 de 3
      • Be careful and work slowly—the cable is extremely delicate, especially near the sensor. Don't try to lift the sensor itself yet.
      • Slowly slide an opening pick under the ambient light sensor cable, starting under the connector at the bottom and working upwards until the cable is free from the screen.
      • If the adhesive doesn't peel up easily, apply more heat.
      Demander à FixBot
    6. iPhone 16 Pro Screen Replacement, Reheat the ambient light sensor: étape 25, image 1 de 1
      Demander à FixBot
    7. iPhone 16 Pro Screen Replacement, Pry up the ambient light sensor: étape 26, image 1 de 3 iPhone 16 Pro Screen Replacement, Pry up the ambient light sensor: étape 26, image 2 de 3 iPhone 16 Pro Screen Replacement, Pry up the ambient light sensor: étape 26, image 3 de 3
      • Work slowly to avoid tearing the thin cable attached to the ambient light sensor. If it feels stubborn, apply more heat instead of using more force.
      • Use the flat end of a spudger to slowly pry up the ambient light sensor from the side with the protruding cable.
      • Remove the ambient light sensor.
      Demander à FixBot
    8. iPhone 16 Pro Screen Replacement, Prepare the ambient light sensor: étape 27, image 1 de 1
      Tesa 61395 Tape
      $2.95
      • Use tweezers to reposition any adhesive that may have covered the ambient light sensor during removal. The adhesive should form a border around the raised rectangle.
      • If the adhesive was damaged or stayed with the old screen, replace it with a 1 mm wide strip of thin, double-sided tape along its top border.
      Demander à FixBot
    9. iPhone 16 Pro Screen Replacement, Place the ambient light sensor: étape 28, image 1 de 2 iPhone 16 Pro Screen Replacement, Place the ambient light sensor: étape 28, image 2 de 2
      • Align the ambient light sensor with its recess in the back of the screen.
      • Use a spudger or your finger to press the ambient light sensor into its recess.
      Demander à FixBot
    10. iPhone 16 Pro Screen Replacement, Warm the ambient light sensor cable: étape 29, image 1 de 1
      • Use a hair dryer, heat gun, or iOpener to soften the adhesive under the ambient light sensor and its cable. It only needs to be warm—not hot.
      Demander à FixBot
    11. iPhone 16 Pro Screen Replacement, Press the ambient light sensor: étape 30, image 1 de 3 iPhone 16 Pro Screen Replacement, Press the ambient light sensor: étape 30, image 2 de 3 iPhone 16 Pro Screen Replacement, Press the ambient light sensor: étape 30, image 3 de 3
      Tesa 61395 Tape
      $2.95
      • Use your finger to press down the ambient light sensor cable.
      • If the ambient light sensor cable isn't sticking, apply a few small pieces of thin, double‑sided tape, like Tesa tape, to the back of the sensor cable.
      Demander à FixBot
    12. iPhone 16 Pro Screen Replacement, Install the ambient light sensor bracket: étape 31, image 1 de 3 iPhone 16 Pro Screen Replacement, Install the ambient light sensor bracket: étape 31, image 2 de 3 iPhone 16 Pro Screen Replacement, Install the ambient light sensor bracket: étape 31, image 3 de 3
      • Use tweezers or your fingers to hook the ambient light sensor bracket over the back of the sensor and set it into place.
      Demander à FixBot
    13. iPhone 16 Pro Screen Replacement: étape 32, image 1 de 1
      • Use a Phillips screwdriver to install the 1 mm‑long screw securing the bracket on the ambient light sensor.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Remove the adhesive and its residue: étape 33, image 1 de 2 iPhone 16 Pro Screen Replacement, Remove the adhesive and its residue: étape 33, image 2 de 2
      • Use a spudger or tweezers to remove the adhesive chunks from the iPhone's frame.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      Demander à FixBot
    2. iPhone 16 Pro Screen Replacement: étape 34, image 1 de 1
      • If you're reinstalling your existing screen, be sure to remove any remaining adhesive from the back of your screen as well.
      Demander à FixBot
    3. iPhone 16 Pro Screen Replacement: étape 35, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 35, image 2 de 2
      • Using a lint-free cloth (or coffee filter) and some high concentration (>90%) isopropyl alcohol, clean the areas of the frame and screen where you removed the old adhesive.
      • For best results, swipe your cleaning cloth in one direction, not back and forth.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Demander à FixBot
    4. iPhone 16 Pro Screen Replacement, Apply the replacement adhesive: étape 36, image 1 de 1
      • Lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout to visualize how the adhesive will lay in the frame.
      Demander à FixBot
    5. iPhone 16 Pro Screen Replacement: étape 37, image 1 de 1
      • Grasp the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Demander à FixBot
    6. iPhone 16 Pro Screen Replacement: étape 38, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 38, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 38, image 3 de 3
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of your iPhone's frame.
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • When it's correctly aligned, gently press the exposed adhesive strip into place.
      Demander à FixBot
    7. iPhone 16 Pro Screen Replacement: étape 39, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 39, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 39, image 3 de 3
      • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Demander à FixBot
    8. iPhone 16 Pro Screen Replacement: étape 40, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 40, image 2 de 2
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Don't press too hard, or you'll stretch and deform the adhesive.
      Demander à FixBot
    9. iPhone 16 Pro Screen Replacement: étape 41, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 41, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 41, image 3 de 3
      • Use a spudger or your fingers to lift the pull tab connected to the large front liner—the pull tab is often in a corner of the liner.
      • Use the pull tab to peel off the large front liner from the adhesive.
      • At this point, you may still have liners covering the perimeter, which prevent the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
      Demander à FixBot
    10. iPhone 16 Pro Screen Replacement, Reconnect the screen: étape 42, image 1 de 2 iPhone 16 Pro Screen Replacement, Reconnect the screen: étape 42, image 2 de 2
      • Use your finger to press down and connect the display connector.
      • To re-attach wide press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • Press down and connect the front sensor connector.
      • Align the connector carefully over its socket and press down with your fingertip until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • This is a good time to power on your iPhone and test all functions before you seal it up. Be sure to power your iPhone back down completely before you continue.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      Demander à FixBot
    11. iPhone 16 Pro Screen Replacement, Install the connector covers: étape 43, image 1 de 2 iPhone 16 Pro Screen Replacement, Install the connector covers: étape 43, image 2 de 2
      • Tuck the display connector cover's tab into its frame cutout and lay the cover in place.
      • Repeat with the front sensor connector cover.
      Demander à FixBot
    12. iPhone 16 Pro Screen Replacement: étape 44, image 1 de 1
      • Use a tri-point Y000 driver to install the two 1.3 mm‑long screws securing the two connector covers.
      Demander à FixBot
    13. iPhone 16 Pro Screen Replacement, Remove the final liners: étape 45, image 1 de 3 iPhone 16 Pro Screen Replacement, Remove the final liners: étape 45, image 2 de 3 iPhone 16 Pro Screen Replacement, Remove the final liners: étape 45, image 3 de 3
      • While supporting the screen, use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
      • Be careful not to touch the exposed adhesive.
      • Check the frame and screen for any stray liners and remove them. There should be no liners remaining.
      Demander à FixBot
    14. iPhone 16 Pro Screen Replacement, Install the screen onto the frame: étape 46, image 1 de 2 iPhone 16 Pro Screen Replacement, Install the screen onto the frame: étape 46, image 2 de 2
      • Carefully align the screen's top clips with their frame cutouts.
      Demander à FixBot
    15. iPhone 16 Pro Screen Replacement: étape 47, image 1 de 3 iPhone 16 Pro Screen Replacement: étape 47, image 2 de 3 iPhone 16 Pro Screen Replacement: étape 47, image 3 de 3
      • Lower the screen onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Make sure the screen edge isn't pinching any cables.
      Demander à FixBot
    16. iPhone 16 Pro Screen Replacement, Apply heat to the perimeter: étape 48, image 1 de 1
      • Use a hair dryer, heat gun, or an iOpener to heat the screen perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Apply pressure to the perimeter: étape 49, image 1 de 2 iPhone 16 Pro Screen Replacement, Apply pressure to the perimeter: étape 49, image 2 de 2
      • Use your fingers to firmly squeeze around the perimeter of the iPhone.
      Demander à FixBot
    2. iPhone 16 Pro Screen Replacement: étape 50, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 50, image 2 de 2
      • Place your iPhone screen-side down on a clean, flat work surface.
      • Lay a strip of tape around the perimeter of the back glass to protect the finish.
      • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
      • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
      Demander à FixBot
    3. iPhone 16 Pro Screen Replacement: étape 51, image 1 de 2 iPhone 16 Pro Screen Replacement: étape 51, image 2 de 2
      • Place 3-4 heavy books squarely on top of your iPhone.
      • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
      • Leave the books in place for about 30 minutes.
      • The pressure will help activate the adhesive.
      Demander à FixBot
    1. iPhone 16 Pro Screen Replacement, Install the pentalobe screws: étape 52, image 1 de 2 iPhone 16 Pro Screen Replacement, Install the pentalobe screws: étape 52, image 2 de 2
      • Use a P2 pentalobe screwdriver to install the two 7.4 mm‑long screws on either side of the USB-C port.
      Demander à FixBot
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
17 autres ont terminé cette réparation.
Nick Schultz
Membre depuis le 03/24/24
60 030 Réputation
318 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
63 227 tutoriels rédigés
2 commentaires de tutoriel
I would like to recommend that when you are removing the screen assy. start at the bottom as this procedure recommends. But rather than going up the left side of the phone proceed up the right side, to about 3/4 of the way (Just above the power button). There are far fewer obstacles on that side. Reheat the phone and proceed up the left side about 3/4 of the way, while adhering to the 3mm depth restriction. Reheat again and wiggle the top to release the clips and proceed to release the top. BTW I use a hot plate (set at 65 degrees C) to heat the phone for 10 minutes to soften the adhesive. I also use a single edge razor blade (only on the bottom of the phone) to create the gap to start the process of lifting the screen assy. Do Not use the razor blade anywhere else though. The suction cups can be problematic on screens that are badly broken.
Garry Roy - Réponse Partager
@rpchc I agree, the instructions oddly recommend going up the route where you can break stuff easily. I had to order a part for $15, could have been easily avoided had I gone up the other side.
Noah Larmann - Réponse Partager
Nombre de vues :
Dernières 24 heures : 116
7 derniers jours : 699
30 derniers jours : 2,674
Total : 29,700
