Aller au contenu principal
iPhone 4S Battery Replacement
Ce dont vous avez besoin
  1. iPhone 4S Battery Replacement, Pentalobe Screws: étape 1, image 1 de 1
    • Remove the Bottom Pentalobe Screws next to the charger connecter.
    • It is recommended that you use a small 5-Point screwdriver.
    • Remember to make sure your iPhone is fully turned off before tearing it down, to prevent serious injury.
  2. iPhone 4S Battery Replacement, Back Panel Removal: étape 2, image 1 de 2 iPhone 4S Battery Replacement, Back Panel Removal: étape 2, image 2 de 2
    • Push the back panel towards the top edges of the iPhone. Doing this should allow the back to slide off.
    • Do NOT apply so much pressure. Especially if your iPhone is cracked.
    • Do not rush it! Time is key.
  3. iPhone 4S Battery Replacement, Battery Screws: étape 3, image 1 de 1
    • Remove these two screws that are securing the battery connecter to the Logic Board.
    • Remember to focus and pay attention. So you don't accidentally slip and pierce the Battery!
    • For the bottom screw, it is recommended that you use a 1.5 mm Screwdriver, and a 1.7 mm for the top screw.
  4. iPhone 4S Battery Replacement, Battery Strip: étape 4, image 1 de 1
    • Locate and pull the Plastic tab to pull out battery. Make sure to pry up outsides of battery on other sides as well.
    • Do not pull the plastic tab to hard, as it can easily rip!
  5. iPhone 4S Battery Replacement, Battery Removal: étape 5, image 1 de 1
    • Carefully remove the battery.
    • Remember, if you are replacing your battery, remember to preform a hard reset on your iPhone once its all finished.
60 autres ont terminé cette réparation.
Cole Anello
Membre depuis le 11/01/16
1 986 Réputation
1 tutoriel rédigé
Un commentaire
la olum bunu benim 1 yaşında kızım da biliyo
ahmetceylanbm - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 39
30 derniers jours : 149
Total : 20,661
