Aller au contenu principal
iPhone 5c Logic Board Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. iPhone 5c Logic Board Replacement, Logic Board: étape 1, image 1 de 3 iPhone 5c Logic Board Replacement, Logic Board: étape 1, image 2 de 3 iPhone 5c Logic Board Replacement, Logic Board: étape 1, image 3 de 3
    • Use a spudger to disconnect the Lightning connector ribbon cable from its socket on the logic board.
    • The Lightning connector cable is lightly adhered to a shield on the logic board. Use the flat end of a spudger to gently peel the cable up.
  2. iPhone 5c Logic Board Replacement: étape 2, image 1 de 2 iPhone 5c Logic Board Replacement: étape 2, image 2 de 2
    • Flip the Lightning connector cable up out of the way of the logic board.
  3. iPhone 5c Logic Board Replacement: étape 3, image 1 de 1
    • Disconnect the lower antenna connector from the base of the logic board.
  4. iPhone 5c Logic Board Replacement: étape 4, image 1 de 2 iPhone 5c Logic Board Replacement: étape 4, image 2 de 2
    • Use the flat end of a spudger to disconnect the audio control cable connector from its socket on the logic board.
    • Disconnect the rear-facing camera cable connector from its socket on the logic board.
  5. iPhone 5c Logic Board Replacement: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    • A small piece of tape may obscure the logic board grounding clip. If so, use a pair of tweezers to remove the tape.
  6. iPhone 5c Logic Board Replacement: étape 6, image 1 de 2 iPhone 5c Logic Board Replacement: étape 6, image 2 de 2
    • Remove the following screws securing the logic board grounding clip to the rear case:
    • 1.2 mm Phillips #000 in the top side-wall
    • 2.5 mm Phillips #000
  7. iPhone 5c Logic Board Replacement: étape 7, image 1 de 1
    • Use tweezers to remove the logic board grounding clip.
  8. iPhone 5c Logic Board Replacement: étape 8, image 1 de 1
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Three 2.7 mm standoff screws
    • Standoff screws are best removed with a standoff screwdriver or standoff driver bit. A small flathead screwdriver can also do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  9. iPhone 5c Logic Board Replacement: étape 9, image 1 de 3 iPhone 5c Logic Board Replacement: étape 9, image 2 de 3 iPhone 5c Logic Board Replacement: étape 9, image 3 de 3
    • Holding the phone level, lift the bottom end of the logic board up enough to grasp it with your fingers.
    • Pull the logic board away from the rear-facing camera just enough to expose the gold contact cap under the top end of the board.
    • Remove the gold-colored contact cap from the threaded post in the rear case, and set it aside.
  10. iPhone 5c Logic Board Replacement: étape 10, image 1 de 2 iPhone 5c Logic Board Replacement: étape 10, image 2 de 2
    • Flip the logic board up toward the volume control buttons to expose the antenna connector.
    • Do not try to remove the logic board from the rear case yet, as it is still connected by an antenna cable on the back.
  11. iPhone 5c Logic Board Replacement: étape 11, image 1 de 1
    • Disconnect the antenna connector from the back of the logic board.
  12. iPhone 5c Logic Board Replacement: étape 12, image 1 de 1
    • Remove the logic board from the rear case.
Andrew Optimus Goldheart
Membre depuis le 10/17/09
508 631 Réputation
407 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
118 membres
19 418 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 3
Total : 217
