Introduction
iTunes error codes are very common and it may pop up when you try to restore your phone or update to the new system. REWA LAB has summarized common iTunes error codes of iPhone 6 / 6 Plus and the troubleshooting thoughts of these iTunes error codes.
Vidéo d'introduction
iTunes error code 1 is usually related to baseband CPU, baseband PMU and the 19.2MHz crystal oscillator.
We can replace the baseband PMU and the crystal oscillator if the two are damaged.
iTunes error code -1 is usually related to baseband EPROM.
Check whether baseband EPROM is pseudo soldered or damaged.
iTunes error code 56 is usually related to NFC chip and rear camera.
Since NFC chip has a high rate of damage, our first move is to check whether it is pseudo soldered or damaged.
iTunes error code 4013 and 4014 is usually caused by pseudo soldering or damage of CPU.
iTunes error code 2005 is usually caused by low battery of the phone or damage of the battery.
iTunes error code 9, 14, 40, 2009 and 4005 is usually caused by damage of the NAND flash or failure of NAND flash relevant circuits.
As for iTunes error code 3194, first thing we to do is to check the network and connection between phone and computer.
If nothing goes wrong, check the charging port flex and charging port connector.
Before seeking for logic board solution, you can rule out some basic causes first.
1. Update iTunes to the latest version.
2. Update your computer to the latest OS.
3. Restart your computer and soft reset your iOS device.
4. Unplug and plug in your iOS device to try again.
- How to Fix iPhone 7 No Service
- How to Fix iPhone 7 Hey Siri Not Working
- iPhone 7 Plus Touch ID Not Working – Broken Home Button Cable Repair
- How to Fix iPhone 7 Rear Camera Keeps Shaking
- How to Fix iPhone 7 Plus Half Backlight
- How to Fix iPhone 7 Plus Won't Turn On After Water Damage
- iPhone 6 Won't Turn On - Water Damage Repair
- How to Fix Samsung S7 edge Won't Turn on - Logic Board Solution
