Introduction
Use this guide to remove or replace the volume button covers in your iPhone 7. This guide is for the physical buttons, and not the electronic switches beneath.
If you need to replace the volume control cable, follow this guide.
Ce dont vous avez besoin
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Outil utilisé dans cette étape :Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Apply a suction cup to the lower half of the front panel, just above the home button.
Outil utilisé dans cette étape :Tri-point Y000 Screwdriver$5.99
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press to eject the tray.
Remove the SIM card tray assembly from the iPhone.
Use the flat end of a spudger to disconnect the rear-facing camera connector.
Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
Use a pair of tweezers with blunt tips to peel back one of the adhesive strips on the lower edge of the battery.
Outil utilisé dans cette étape :Plastic Cards$2.99
Prepare an iOpener and apply it to the back of the rear case, directly over the battery. Alternatively, you can apply heat using a heat gun or hair dryer.
After about a minute, remove the iOpener, flip the phone over and use a plastic card to break up any remaining adhesive behind the battery.
Remove the following Phillips screws:
Two 1.9 mm screws securing the power button.
Three 2.3 mm screws securing the volume buttons.
Pull the volume button clip towards the bottom of the phone to free it from the bracket.
Slide the flat end of a spudger underneath the bottom edge of the volume button bracket.
Adjust the spudger so that it can move away from the rear case without contacting the protruding peg that is on the volume button.
Rotate the spudger to pop the bracket off of the peg on the volume button.
31 autres ont terminé cette réparation.
10 commentaires
Hi Alex, the repairability of water damage varies hugely depending on your unique circumstances, but this guide is a good place to start. If the damage is extensive you may want to take your phone to a local repair professional.
Bonjour je voudrais savoir si vous avais la même explication mais pour iPhone 7+ s’il vous plaît ??
