Introduction
更换 iPhone X 显示组件通常不会影响 Face ID。 但是,我们收到客户的投诉,称更换显示屏组件后手机上的 Face ID 出现故障。 我们做了一些研究,我们猜测问题可能是在更换过程中操作不当,导致柔性电缆或其他组件损坏。
Vidéo d'introduction
系统提示,”无法在此iPhone上激活面容ID”。
设置面容ID时,系统提示,面容ID不可用。
根据客户描述,该机在被摔过后面容ID可以正常使用。然而更换总成后,面容ID不可用
该机面容ID不可用,可能是由于更换总成时操作不规范引起的。
22 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
7 commentaires
Why not just buy a new cable? They’re $10-$15 on eBay. Soldering seems like it’s take way more time and possibly even cost more money than just buying a new cable.
Face ID will no longer function if the original flex connectors are damaged or replace with new ones. Even if the flex connectors are properly soldered just as they were originall it will still fail. There is some marker in the cables which the module is checking for and if the cables are changed then the marker (most likely the serial number of the flex) will mismatch and fail to work. The same was true with Touch ID as well
What brian said is correct, if the cable is changed it will not match.This full video looks more detailed(21) Troubleshooting iPhone X Problems of Floodlight Sensor, True Tone, and Face Recognition - YouTube,
