Introduction
Rosin and the freeze spray are the two commonly used and low-cost methods for faulty components locating when repairing logic boards. Still, you can use the Thermal Imager instead for more efficient repair work if the two methods become time-consuming. Check our iPhone X repair guide today and you will be surprised at how the Thermal Imager is used in iPhone X won’t turn on repair. Also, for repair technicians, it’s important for you to understand how iPhone X boot circuit works before starting your repair work.
Vidéo d'introduction
Hold the power button to turn on the phone. The phone won’t turn on.
Take apart the phone and disconnect the battery. Remove the screen and take out the motherboard.
Let’s check the boot current first. The boot current is larger than normal value.
Touch the motherboard with one hand. The NAND flash chip and the area surrounding it are hot.
Since there are so many components on the hot area, we can locate the faulty component with the help of the Thermal Imager.
Put the motherboard under the Thermal Imager. Get the motherboard powered on. We can see clearly that C2647 is extremely hot. Judging by this, C2647 is probably damaged.
- iPhone 11 Series Non-Genuine Screen Warning/Important Display Message - 100% Fix
- '''How To Restore True Tone After Screen Replacement On iPhone XS'''
- '''How to Fix iPhone X Face ID Not Available'''
- '''How to Fix iPhone X Face ID Not Working After Screen Replacement'''
- '''Upgrade iPhone X 64GB Storage To 256GB In 5 Steps'''
- '''How to Restore A Badly Damaged iPhone X'''
- Samsung Galaxy S9/S9+ Cracked Screen Glass Only Repair
- One Solution To Fix 80% iPhone Touch ID Failure
2 autre(s) ont terminé cette réparation.
