Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
There are usually two different causes for not working issue of iPhone portrait mode. Software problem or hardware problem. For software problems, we can fix it by restarting the phone, upgrading iOS or restoring to factory mode. For hardware problems, check our video today, iPhone XS Max portrait mode not working motherboard repair and you shall get enlightened.
Vidéo d'introduction
  1. Open the camera app and swipe to portrait mode. We can see clearly that the background is not blurred.
    • Open the camera app and swipe to portrait mode. We can see clearly that the background is not blurred.
    • Which indicates that the wide-angle lens is working normally, while the telephoto lens is not working at all.
  2. Run diode mode measurement of the Tele camera connector J4000. The measured value of Pin 25 is OL, which is abnormal.
    • Run diode mode measurement of the Tele camera connector J4000. The measured value of Pin 25 is OL, which is abnormal.
    • The first thing we do is to check the zero-ohm resistor R4006 on Pin 25 relevant circuit. Nothing goes wrong.
    • We can confirm that the fault is probably related to U3700, the camera power supply IC on the circuit.
    • Let's try to replace with a new IC.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Place the motherboard on the Heating Platform, which can quickly desolder&resolder iPhone XS Max double-layer motherboard.
    • Place the motherboard on the Heating Platform, which can quickly desolder&resolder iPhone XS Max double-layer motherboard.
    • Pick up the upper layer with tweezers once solder on the third space PCB has melted.
  5. Detach U3700 from the board with Hot Air Gun.
    • Detach U3700 from the board with Hot Air Gun.
    • Clean the bonding pad and then solder a new IC.
  6. Next thing we do is to solder the two layers together.
    • Next thing we do is to solder the two layers together.
    • Clean the third space PCB with rosin soaked Solder Wick first. Then reball the lower layer.
    • Get the upper layer and the lower layer in position. Power on the Heating Platform.
    • Several minutes later, power off and wait for the motherboard to cool for 5 minutes.
  7. Open the camera app and swipe to Portrait Mode. We can see that the subject is being focused and the background is blurred.
    • Open the camera app and swipe to Portrait Mode. We can see that the subject is being focused and the background is blurred.
Phryne
Membre depuis le 17/11/2019
10 221 Réputation
80 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 16
7 derniers jours : 86
30 derniers jours : 404
Total : 2,119
