Introduction
La batterie ne tient plus la charge ? Remplacez-là.
Ce dont vous avez besoin
Décollez la batterie de l'adhésif qui la maintient à l'iPod.
Laissez la batterie à côté de l'iPod (elle est toujours connectée à la carte mère).
Déconnectez méticuleusement le connecteur blanc de la batterie de la carte mère. Soyez sur de tirer uniquement sur le connecteur lui-même et non sur les câbles.
Pour remonter votre appareil, suivez les étapes dans l'ordre inverse.
32 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
2 commentaires
There are so many iPods, it's confusing as to what battery to buy. I have 3 of these old bricks and sure it's battery time. Can you please provide a link to the specific battery for this (above) iPod?
The iPod that I,m trying to resssurect has a connection that has 50t pin connection. I ordered the battery shown in the picture and now have to exchange it
Boy, are these cases hard to open! I got nowhere with the spudger, but I did have success using duct tape. This is worth trying as it reduces the likelihood of scratching the case. Make a tab by sticking duct tape to the metal case starting on the side down by the scrolll wheel and ending up where the metal case ends on the firewire side. Fold excess duct tape back on itself so that it is 2x thick anywhere it isn’t stuck to the iPod. This is where you are going to grab it. Rub the duct tape with a spudger or a fingernail where it touches the iPod to make it stick better. Make a similar tab on the other side. Now grab the iPod in your right hand with your thumb at the 1/8” audio connector, squeeze gently, and pull on one of the duct tape tabs. (I stared with the one of the lock button side, but I don’t think it matters.) It is smooth sailing once the case starts to open up. Clean off any duct tape residue with alcohol wipes before re-assembly.
R Calhoun - Réponse
Well, maybe for you because you have baby hands and, it Took me less Then a minute to do it
Matthew Cabanas -
