Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre iPod Nano 1st Generation, utilisez notre manuel de réparation.
  1. iPod Nano 1st Generation Teardown, Open The iPod: étape 1, image 1 de 2 iPod Nano 1st Generation Teardown, Open The iPod: étape 1, image 2 de 2
    • 1. Using an ipod unclipping tool (which could be a knife or similar to it), unclip the outer casing by putting the tool up to the connection point. This should pop the case off. Note that force will need to be used.
  2. iPod Nano 1st Generation Teardown: étape 2, image 1 de 1
    • 2. Remove the circuit board by unscrewing the 3 screws (there is 1 more screw but dont unscrew it, it holds the headphone jack) that hold it down. Note that specialised screwdrivers may need to be used.
  3. iPod Nano 1st Generation Teardown: étape 3, image 1 de 2 iPod Nano 1st Generation Teardown: étape 3, image 2 de 2
    • 3. Carefully remove the connected wires underneath the motherboard to disconnect the clickwheel and the screen.
  4. iPod Nano 1st Generation Teardown: étape 4, image 1 de 3 iPod Nano 1st Generation Teardown: étape 4, image 2 de 3 iPod Nano 1st Generation Teardown: étape 4, image 3 de 3
    • 4. The screen has 3 different sections, each held down by glue so necessary force is needed. First remove the acrylic backing that supports the screen and then the main part of the screen. The last thing to remove is the paper-thin cover.
  5. iPod Nano 1st Generation Teardown: étape 5, image 1 de 3 iPod Nano 1st Generation Teardown: étape 5, image 2 de 3 iPod Nano 1st Generation Teardown: étape 5, image 3 de 3
    • 5. Removing the touchpad is easy and simple as there are layered parts on top of each other, just simply and carefully pull them off.
  6. iPod Nano 1st Generation Teardown: étape 6, image 1 de 1
    • 6. Finally you should have the ipod dismantelled and you should be able to put the ipod back together.
Craig Lawrence
Membre depuis le 03/11/10
444 Réputation
1 tutoriel rédigé
6 commentaires
when i put the rear cover back on, the charging station doesn't line up correctly and the charging station sticks out a bit. any advice?
krnchang - Réponse
is the batter swollen
Derek King - Réponse
Yes, happened to a Zune 80 I have
CTCL -
Thank you for this - took the fear factor out of changing battery on my much loved Nano!
jimbradshaw - Réponse
It’s extremely hard to connect LCD and Button cables. I screwed it up while reconnecting the cables. IF, you want to disassemble this machine by fun, don’t ever try it.
Sizun Cho - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 35
30 derniers jours : 148
Total : 28,549
