Introduction
Use this guide to replace the external volume rocker on your iPod. The volume control buttons are soldered to the logic board, this guide will only show you how to replace the button cover, not the mechanical buttons.
Ce dont vous avez besoin
Fill a pot or pan with enough water to fully submerge an iOpener.
Heat the water to a boil. Turn off the heat.
Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
Use tongs to extract the heated iOpener from the hot water.
Thoroughly dry the iOpener with a towel.
Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
Lay the iOpener over the plastic tab to loosen the adhesive. Let the bag sit on the device for approximately 90 seconds before attempting to open the panel.
Remove the two 1.4 mm Phillips #000 screws from the sleep/power button bracket.
4 autres ont terminé cette réparation.
