Aller au contenu principal
iPod Shuffle 4th Generation Rear Panel Replacement
Ce dont vous avez besoin
  1. iPod Shuffle 4th Generation Rear Panel Replacement, Rear Panel: étape 1, image 1 de 1
    • Accessing the internals of the 4th generation Shuffle is extremely difficult, as the rear panel is both glued to the front case and secured by metal retaining clips. It is highly unlikely that you will be able to remove the rear panel without inflicting cosmetic and/or structural damage.
    • Before proceeding, be sure your Shuffle is switched off.
  2. iPod Shuffle 4th Generation Rear Panel Replacement: étape 2, image 1 de 2 iPod Shuffle 4th Generation Rear Panel Replacement: étape 2, image 2 de 2
    • Use a combination of iPod opening tools and metal spudgers to pry the rear panel away from the Shuffle by the seam nearest the ON/OFF switch.
    I managed to open mine using no tools at all so without damage. Maybe the glue also weakened over time so might need to use some heat. I didn’t but then again it’s a second hand, old device in my case.
    I used the clip on the back as a leverage to (ever so slightly) bend the back piece in the center. Having that bend is enough for the very small clips on the power switch side to detach. Once that side is removed you can slide the complete back out towards the direction of the power switch. I checked on a flat surface and the piece isn’t damaged, still straight. Just don’t keep it bend too long and don’t over bend it. It really shouldn’t take much since those notches are really small.
    To close it again just slide the back side in again and then snap the power switch side back in place by lightly pressing it on top. Since the clips aren’t damaged this way it will close up nicely. If the notches got damaged you’ll have to use glue instead (hot glue will do and is easily removable again).
    Ha ns - Réponse
    what do you mean by bend the back piece in the center?! How do you do that exactly? Did you stick something in between the back piece and the clip and press in?
    Jackson Chan - Réponse
    I completely agree with Ha ns' comment. I really cannot understand how the author managed to open this device as described. There must be something like a 0.1mm gap between the housing and the cover, impossible to enter a spudger or pry tool. Use a lever on the hinged side of the clip to lift the cover, insert a 0.2mm plastic film or a thin plectrum or spudger on the bent center of the cover. Avoid to push the spudger down, as there are electronic components underneath, only lift the cover, without overbending. Move over to the side of the on/off switch, and release the 3 clips. On the other end an 8mm long nose will avoid lifting off the cover. You will have to slide it out horizontally. Clearly: you have to be very very careful and gifted...
    cloclolulu - Réponse
  3. iPod Shuffle 4th Generation Rear Panel Replacement: étape 3, image 1 de 1
    • Remove the rear panel from the Shuffle.
5 autres ont terminé cette réparation.
2 commentaires
what glue to fix it?
pedro_bizarro - Réponse
I recommend 2mm TESA tape
Ben Capehart -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 9,496
